Way too much fuel!
I would check your fuel filter. Make sure it's installed correctly and not plugged up. Usually the factory ones had a spring behind them that when they are plugged, they bypassed by compressing the spring. If your fuel system is dirty, the carb float system will never be able handle the dirt and always flood.
I will check the vent if I can identify which it is. There's 3 vacuum type lines and one which runs to the canister which I assume is the vent. The fuel filter is new but I feel like it is the cause of this whole issue, I might put a different style one on it. How would I check fuel pressure on such a low pressure system?
Sounds like very high fuel pressure which is overcoming the needle and overfilling the bowl.
Do you have a fuel pressure/vacuum gauge? If so you can install a tee between the pump and the carb and see what the pressure is. The 1981 factory shop manual says the 4.9L is to have from 5 to 7 psi at idle in neutral, and the pump should deliver 1 pint of fuel in 20 seconds.
Take care.
Gas in the oil could be by flooding the intake and running past the rings. That is really hard on cylinder walls as the oil gets washed off of them. Or, it can be via the pump's diaphragm, as Cliff said. In either case you need to change the oil quickly as oil with gas in it doesn't lube very well.
Take care.
#28
#29
I'm interested to see how this turns out. I'm having a similar problem with my 78'. It ran great until I popped the carb off and cleaned it. Now it shoots gas everywhere like a volcano and won't run very well, or very long. It must be pressure related, because when I take the top off and turn on the pump (I have an electric one which is adjustable) it doesn't do it. either that, or the float is hitting something and keeping the thing from sealing.
