An interesting suspension arrangement - Ford Truck Enthusiasts Forums
Old 07-12-2014, 09:01 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
found this cruising craigslist. Wonder how that thing rides and handles.
1949 Ford F1 Rat Rod Project
Old 07-12-2014, 09:33 PM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
What an abortion. I believe I am being kind. I am amazed that someone will put new tires on a project that is no where near road worthy.
Old 07-12-2014, 10:40 PM
mgargiullo's Avatar
mgargiullo mgargiullo is offline
mgargiullo is starting off with a positive reputation.
I'd give him $500 and he can keep the tires. Whoever setup that front end should have their tools taken from them before they hurt themselves.
Old 07-12-2014, 10:51 PM
4tl8ford's Avatar
4tl8ford 4tl8ford is offline
4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold4tl8ford is a splendid one to behold
I see about 12 laws of automobile physics being broken
Old 07-12-2014, 11:14 PM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
I highly doubt it would ever drive or handle safely. There is too much wrong with that to even give it semi-credibility by criticizing or discussing it. Looks like they simply turned the chassis upside down!
Old 07-13-2014, 12:13 AM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
New meaning to the term "axle flip"..........
The word "deathtrap" also comes to mind.
Old 07-13-2014, 08:48 AM
EffieTrucker's Avatar
EffieTrucker EffieTrucker is online now
Kentucky Chapter Member
EffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to beholdEffieTrucker is a splendid one to behold
There are a few guys that do a lot of engineering and spend a lot of time, money, and effort to get their Rat Rod's suspension geometry "Right". Then there are the other 98%. Guess which category this one falls under.
Old 07-13-2014, 09:05 PM
Giesterfarher™'s Avatar
Giesterfarher™ Giesterfarher™ is offline
Giesterfarher™ is starting off with a positive reputation.
Looks like all he did was turn the frame upside down and mount the cab on it. If so, it's salvageable.
Old 07-13-2014, 09:53 PM
Quote:
Looks like they did re-stack the spring packs. I wonder if they bent the axle and flipped the spindles right side up to correct the camber angle?
Never mind. I can see in the pic the tie rod arms are on top.
Old 07-13-2014, 09:59 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
What's sad is that there are two other cars/trucks in the background, undoubtedly waiting for similar treatment...
Old 07-13-2014, 10:00 PM
theGman's Avatar
theGman theGman is offline
theGman is starting off with a positive reputation.
Just when you thought you'd seen it all...
tinman52's Avatar
Welder User
The frame isn't flipped, just the entire front suspension.....including the spring hangers.
The builder obviously has no clue about scrub lines, kingpin inclination, ackerman angle, scrub radius, etc, etc. Or just wanted to look "kool".
Hopefully someone doesn't buy that and try to put it on the street like it is......
Old 07-13-2014, 11:38 PM
ALBUQ F-1's Avatar
postin' fool
I can't quite get my head around it, but wouldn't the steering be reversed now?
Old 07-13-2014, 11:52 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Scott, I have never herd of most of those things you just mentioned, but one dosn't need to, too know that thing is just wrong, and unsafe. The one good thing about this rat rod is, because of it being posted, now I will look up, what scrub lines, scrub radius, and ackerman angles are. I always learn something when I log in to "The University of FTE"
Old 07-14-2014, 12:24 AM
Quote:
No, the drag link pushing the arm away will still result in the wheels steering to the left.
The problem is it's now a foot above the steering box. Talk about bump steer.
If you flipped the pitman arm to make up for the flipped axle, that would reverse the steering.
oohhh boyy look at this craigslist deal easyridin 1987 - 1996 F150 & Larger F-Series Trucks 6 10-13-2015 10:01 PM
Craigslist running boards Hitagain Excursion - King of SUVs 1 05-08-2015 12:59 PM
F-500 for sale cheap on the Craigslist Maltman 1957 - 1960 F100 & Larger F-Series Trucks 0 03-06-2015 12:14 AM
CL '51 Flatbed F5 53FOPAR 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-05-2015 12:29 PM
Good looking truck on craigslist TektonB 1973 - 1979 F-100 & Larger F-Series Trucks 25 06-01-2014 12:01 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
