HELP!!!!
Old 07-13-2014, 11:00 AM
53Mercdriver's Avatar
53Mercdriver
53Mercdriver is offline
HELP!!!!
So I changed the oil, started it up, all good, sun is low in the sky ahhh time for an evening cruise.
53 Merc M100, close the hood NEVER slammed! Had a nice ride time to put her away....
Wont start in the drive way, go to open the hood and neither hood latch is working?????? how the hell do I open the hood!!!!
ANY HELP APPRECIATED!!!
Old 07-13-2014, 11:09 AM
AXracer's Avatar
AXracer
AXracer is offline
Put flat bar under hood pry up while operating latch?
Old 07-13-2014, 06:38 PM
1oldtimer's Avatar
1oldtimer
1oldtimer is offline
Maybe try to push down on the hood nose while operating the latch. Does it feel like the hood latch is opening all the way?.
Old 07-13-2014, 08:01 PM
53Mercdriver
I appreciate the "fix" advice, it didn't budge! hood it tightly fixed. I looked all around it hasn't shifted or anything, latches are tight as usual. I'm just stumped !
Old 07-13-2014, 08:04 PM
53Mercdriver
Unfortunately the hood is fixed in place nothing seems outa place or loose?!!! and you cant get your head up there to have a look. Both latches seem fine as well.
Old 07-13-2014, 09:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Try pushing backwards on the front of the hood while releasing the lever. (Don't dent your hood!)
Old 07-13-2014, 09:12 PM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
You might also try pushing down on both sides of the hood at the cowl. If it's up the least bit it will push the hood forward.
Old 07-13-2014, 10:24 PM
Aus56's Avatar
Aus56
Aus56 is offline
My hood was closed too hard the last time it was at my mechanics. Pushing, pulling, prying with screwdriver didn't do any good. In the end they said they pretty much ended up pulling the grille out to get to it. It has a center grille support which obstructed prying with a screwdriver, and the top bolt of that support was hard to get to with the hood down, making it hard to remove the support to clear the area for prying. I hope you have better luck.
Old 07-13-2014, 11:04 PM
dmack91's Avatar
dmack91
dmack91 is offline
I am not sure how your latch works, but the same thing happened on my 50. The floating alignment/guide pin (with the large spring around it) that comes out of the cowl that the hood latch goes in moved slightly to the side as I closed it, going past the actual latch lever and hooked the arrow-shaped top of the pin in the latch guide hole. Basically I had to work a large flat bladed screwdriver in and push the large guide pin to the side, which allowed it to move and release.
Old 07-14-2014, 09:40 AM
53Mercdriver
OH!!!
well I have my work cut out for me then. As I prev posted the hood is tight, no play anywhere, so its gotta be grabbing on something somewhere, I will give it a shot may take a while, but thx. I believe, well I've been told other then the few lights odds and sods my merc m100 is directly swappable in parts to the F100 so I hope this is the issue.
Again THX!
Old 07-14-2014, 09:42 AM
53Mercdriver
Appreciate the insight, I will have a big look around and see whats what.
Im really new to the old scene, I love it but its very frustrating some times!!!!
Old 07-14-2014, 11:34 AM
dmack91's Avatar
dmack91
dmack91 is offline
When mine did the same thing (I posted earlier), it was jammed hard too - no movement anywhere. I tried a lot of shaking/pulling/etc. After an hour of head scratching and shaking, I found the overtravel problem (luckily my 50 has the two large holes in the front of the hood for access. Good luck.
Raymond
1999 to 2016 Super Duty
01-17-2024 01:41 PM
Larzon
01-31-2012 08:21 PM
53 Meadow Green
05-15-2011 01:59 PM
shwagy357
1966 - 1977 Early Broncos
03-20-2006 09:23 PM
Quick Reply: HELP!!!!
