Headliner sagging.
Old 07-12-2014, 02:23 PM
jle70's Avatar
jle70
jle70 is offline
Headliner sagging.
I have to pull my headliner to install cab lights, it has a some sag to it where it has separated from backing. What adhesive should I use to repair it? Thanks.
Old 07-12-2014, 03:27 PM
Hussler's Avatar
Hussler
Hussler is offline
Not enough information about the exact headliner to be specific. However over the years I've used 3M Brand Spray Adhesive on these types of projects. It comes in different bonding strengths and is available at most auto store outlets. Be careful as once applied it's pretty much a done deal.
Old 07-12-2014, 03:30 PM
jle70's Avatar
jle70
jle70 is offline
Cab overhead liner. The 3m doesn't bleed through fabric?
Old 07-12-2014, 03:53 PM
91 Dually's Avatar
91 Dually
91 Dually is offline
In my experience, the old fabric can not be re-glued. Have to remove the old fabric, wire brush all the old rotten foam off, and glue New foam-backed fabric on the panel.
Old 07-12-2014, 03:55 PM
jle70's Avatar
jle70
jle70 is offline
Best place to get new fabric? Use the same 3m adhesive?
Old 07-12-2014, 04:20 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
About the only thing that will fix it is removing the old fabric and foam and applying new headliner material. A stiff scrub brush will take the foam off in most cases. If you can get your hands on some DAP HHR (high heat resistant) landau top adhesive, that's the best stuff to use. Otherwise, the DAP Weldwood contact cement you can get at a hardware store is fine.
Old 07-12-2014, 04:22 PM
91 Dually's Avatar
91 Dually
fabric shop, upholstery shop.... most auto parts stores and hardware stores sell a couple different spray glues. 3m is possibly the best.
Old 07-12-2014, 06:27 PM
Bearhugger1933's Avatar
Bearhugger1933
Bearhugger1933 is offline
I was told that there is no good way to glue it,I had mine replaced for. 145.00 about a year ago.still looking like new. Jim
Old 07-12-2014, 09:10 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
I redid the headliner in my bronco last year. The upholstery shop wanted $200 with ME removing the headliner and handing it to them.
I went to JoAnn fabric, bought 2 years of material($7) and 2 spray cans of glue($25)
I removed headliner and laid it fabric up on horses
pulled JUST THE FABRIC from the headliner, leaving the foam behind.
Next I laid the new fabric on the headliner and used cloths pins to hold it in place. The took cloths pins off one side and folded fabric off the one side. The sprayed the foam and the back of the fabric. had a friend slowly lay the fabric back down as Wiped out andy wrinkles. Once it was down, I repinned it and did the sme on the other side.
Once the glue was all dry I took a sharp razor and trimmed the excess and cut holes for visors and dome light.
VERY simple project, i will NEVER pay to have another one done
Old 07-12-2014, 09:14 PM
jle70's Avatar
jle70
jle70 is offline
Do you remember what fabric?
Old 07-12-2014, 09:24 PM
Diesel_Brad
Any fabric you want. I went with a Dark heather gray to match my Lightning seats
Old 07-12-2014, 09:52 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
The problem with that is when the fabric starts to delaminate, it's a strong indication the foam is deteriorating.
Old 07-12-2014, 09:54 PM
Bearhugger1933
Good deal,sounds like you did a good job. F
Old 07-12-2014, 09:56 PM
Bearhugger1933
Looks like my finger hit the wrong key.
Old 07-12-2014, 10:21 PM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
There are some installation instructions somewhere in here:
New Ford Full Size Truck, 4 Door Crew Cab Headliner
Quick Reply: Headliner sagging.
