help, problems warm days - Ford Truck Enthusiasts Forums
Old 07-12-2014, 05:28 AM
lars andersson lars andersson is offline
lars andersson is starting off with a positive reputation.
Thumbs up help, problems warm days
Hi
i have an 1940 truck 1 1/2 ton 95 hp and i have got runnings problems warm days
first i thought it was hot fuel with gas in the carburator
but the electric pump will stop, the truck are not going to start, seams dead.
a friend told me to check the circuit braker.
Have someone some experience of this problems ?
Lars Andersson
Sweden
Old 07-14-2014, 01:18 AM
47COE's Avatar
47COE 47COE is online now
47COE is starting off with a positive reputation.
Not starting when hot is a classic sign of a bad coil, or sometimes, a bad condenser.
Old 07-14-2014, 10:40 AM
ok
but why stop the electric fuelpump ?
Old 07-26-2014, 06:50 PM
geomechs's Avatar
geomechs geomechs is offline
geomechs is starting off with a positive reputation.
First of all, where's your electric pump wired in?
Am I correct to understand that the starter engages and the engine is turning over? And it just isn't firing? You may want to check for power at the coil. There's a chance that the electric fuel pump is wired to your ignition switch, which would make sense if your switch was bad. I would be checking your ignition switch and going out from there.
58 f-250 5.0 EFI Engine Swap Help Lars58f250 1957 - 1960 F100 & Larger F-Series Trucks 3 02-12-2016 12:52 AM
OIL winter F150 2006 SwedMartin Oil & Lubrication 2 08-19-2014 10:51 AM
ignition coil resistor lars andersson 1947 and Older Ford Trucks 2 08-03-2014 03:28 PM
1993 E4OD lockup problem larspetter123 Clutch, Transmission, Differential, Axle & Transfer Case 1 07-13-2014 08:51 AM
99 f250 powerstroke loses power up hills 04 superduty Lar 1999 - 2003 7.3L Power Stroke Diesel 8 03-23-2009 01:06 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
