no over drive 07 f150 v8 4.6 - Ford Truck Enthusiasts Forums
Old 07-12-2014, 12:29 AM
sitdown318 sitdown318 is offline
sitdown318 is starting off with a positive reputation.
i had to replace center support snap ring and some friction plates when put tranny back together have no od even when i switch it off on shifter no change drive just barely goes and engine reves way hi
Old 07-12-2014, 03:06 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
How is 1st and 2nd? Did you reseal all of the drums and use seal protectors? Did you replace the direct clutch sealing rings? Did you torque the valve body bolts and make sure the EPC is installed correctly? Did you flush the torque converter and cooler?
Old 07-12-2014, 03:49 PM
No sir I didn't realize I needed to do that I just replace that snap ring and the friction plates,how do I flush the converter and cooler
Old 07-12-2014, 05:09 PM
Which friction plates did you replace and why? Were they burnt?
96 f250 stalls at times. Drives fine. 19mfn96 1987 - 1996 F150 & Larger F-Series Trucks 1 01-18-2016 05:53 PM
1989 ford f 250 stalls problem josephk12 1987 - 1996 F150 & Larger F-Series Trucks 1 07-25-2015 08:39 PM
05 expedition eddieniner 1997-2006 Expedition & Navigator 11 04-30-2015 10:52 AM
Engine dies in drive conyers73 1987 - 1996 F150 & Larger F-Series Trucks 6 11-05-2014 09:25 AM
Front end noise Donald Edmonton 2009 - 2014 F150 5 05-30-2014 09:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
