Need advice. 1994 5.8 SD rebuild
I will need to rebuild my engine soon in the truck in my sig. What I'm wondering is if I do the following will it mess up my SD system too much? I simply want a good solid rebuild without messing with the SD system. I'm not very computer literate so changing to MAF is beyond my abilities.
Here is what I'm thinking of doing
GT40 heads or maybe an aftermarket head like an Edelbrock or something
1.7 rollers with Crane 444232 cam
Edelbrock Performer or Professional Products Typhoon lower intake
Pacesetter longtube headers with a Random Technologies Super Flow Catalytic Converter and a Magnaflow muffler. My exhaust will be mandrel bent and will likely be a 2 1/2" Y pipe going into a 3" exhaust.
Any help or advice will be appreciated, thank you.
If you have an F4TE block then a roller cam conversion would be a good upgrade. You can get the spider, roller lifters and dogbones from any rollerized 5.0 or 5.8; the used sets I've purchased in the past have all been under 100 bucks.
Look into getting an adjustable fuel pressure regulator and an in cab fuel pressure gauge as well because it will likely run lean at higher RPM's, under heavy throttle conditions.
on
Yes actually your motor should already have a roller cam.. I must have been snoozing not to have noticed that earlier. So if that is the case don't go backwords to a flat tappet cam, instead get the Mustang HO roller cam or maybe this one.. http://www.summitracing.com/int/part...view/make/ford
Thank you Conanski. So the Lunati cam you suggest would be more compatible than the Crane 444232 or the Comp Cam 35-255-5 with my 5.8 SD system? I got the cam numbers from reading about cams on FTE so I'm not sure of the choices.
Also, can I use standard length pushrods with the GT40 heads and the suggested cams or do I need to order different ones.
on
The Crane 444232 and Comp 35-255-5 are both flat tappet cams which means you would need matching flat tappet lifters and pushrods. Flat tappet lifters are shorter than roller lifters so flat tappet pushrods are longer. The heads will have no impact on the pushrods needed unless they were machined.
Ah, OK. In all the reading I've been doing I never picked up that the Crane and Comp cams I listed were for flat tappet cams. Once again, thank you for the information.
I'm going to the JY today to see what they have in the way of Mustangs, explorers etc. to look for the GT40 heads.
Cheers
Cheers
Not necessarily. Being that it's speed density would lead me to believe that it doesn't have a roller cam. You can pull a valve cover and look through the head where the pushrods are. If you see a piece that resembles a dogbone, between the lifters, then you have a roller cam in it.
I was reading in another post about someone wanting to rebuild a 302 (5.0 L) and Conanski said, in part (One good thing about this motor is it already wears a really good intake so there is something you won't need to upgrade)
Can I use the 302 upper and lower intakes from a 5.0 L for my 5.8? If so, would it be an upgrade from my current intakes? My local JY has two or three of them still in the truck so some time at the JY and a few dollars works for me if it's advisable.
