battery cable - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
battery cable
Old 07-11-2014, 08:13 PM
rungunner rungunner is offline
rungunner is starting off with a positive reputation.
battery cable
Hello I am asking for a little help, I changed the battery cable in my truck 7.3 diesel, 2 battery's, cable to solenoid on fender and the cable to the starter, now the truck wont turn over, just clicks. I know everything is right to the battery's and to the starter, maybe I messed something up on the fender solenoid. Any ideas? Thanks
Old 07-11-2014, 09:50 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Quote:
I would start with checking the small wire on the starter. After that the ground wire to the block
Old 07-12-2014, 03:02 PM
Starter
I took both wires back off the starter and re-installed them after trying a spare solenoid that did not solve the problem and it runs once again. Thank You
Starting Problems when hot. dominick2006 1987 - 1996 F150 & Larger F-Series Trucks 1 10-31-2015 03:01 PM
1990 f250 5.8 windsor SLOW CRANK issue Ryan Weaver 1987 - 1996 F150 & Larger F-Series Trucks 10 01-04-2015 05:30 PM
'02-'03 Battery cable swap to '99-'01 truck Shake-N-Bake 1999 - 2003 7.3L Power Stroke Diesel 3 09-23-2014 12:27 AM
Battery cable size 78 & 87 Super Cab 1957 - 1960 F100 & Larger F-Series Trucks 4 05-20-2014 05:27 PM
1977 Ford F250 No Crank.....Please Help seth_85 1973 - 1979 F-100 & Larger F-Series Trucks 3 06-19-2013 06:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
