Quick AC Condenser Question: Removal - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-11-2014, 06:12 PM
Spktyr Spktyr is offline
Spktyr is gaining momentum as a positive member of FTE.Spktyr is gaining momentum as a positive member of FTE.
I'm doing a complete AC system rebuild on my truck and I'm at the stage where one is to unbolt and tilt back the radiator to get access to the condenser for removal. The Ford manual is pretty generic, saying to remove the upper heater hose and drain the cooling system. However, it *looks* like if I protect the radiator from the fan (with a sheet of cardboard), I can just unbolt the radiator and tilt it back without draining any coolant because the plumbing is radically different from the gas trucks. Is this the case, or do I have to dump the cooling system? Thanks.
Old 07-12-2014, 01:32 AM
fordman67's Avatar
fordman67 fordman67 is offline
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Can't you pull the grille and header panel and remove from the front.I remounted mine when I did the ic install and I can't see why it would not be easier that way.
Old 07-12-2014, 01:42 AM
My truck has a Ranch Hand style grille guard on the front that is very close to the grille. I am working alone and can't remove and reinstall the guard alone. Not a bad idea, though - if I didn't have the grille guard I might try that.
Old 07-12-2014, 11:20 PM
fordman67's Avatar
Yea...you are pulling the rad.oh well
Old 07-13-2014, 01:49 AM
williameub williameub is offline
williameub is starting off with a positive reputation.
I've always used an engine hoist (or 'cherry picker') to install and remove my grill guard.
Flushing your coolant is also never a bad idea if it's been in there a while...
Old 07-16-2014, 04:48 AM
It turns out the answer to my question is yes - protect the radiator with sturdy corrugated cardboard and it will work just fine with no damage to the radiator. Use more cardboard to protect the condenser from the radiator and the support going in and it'll go in fine too.
core support re/re update with pics sean9049 1994.5 - 1997 7.3L Power Stroke Diesel 3 03-21-2016 04:02 PM
Quick AC Condenser Question: Removal Spktyr 1987 - 1996 F150 & Larger F-Series Trucks 4 07-16-2014 09:03 PM
air conditioner removal plowboy12 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 02-15-2014 11:53 AM
Remove plastic cover in front of radiator? EXv10 Excursion - King of SUVs 7 09-24-2012 12:29 AM
'53 F-100 AC PROB.. CONDENSER TOO FAT jniolon Cooling, Heating, Ventilation & A/C 3 02-24-2012 01:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
