F700 Trans compatability - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 07-11-2014, 05:02 PM
tntitan00 tntitan00 is offline
tntitan00 is starting off with a positive reputation.
OK so I have been browsing and can't find much info on this topic but I have an 88 f700 with a 429 and an Eaton 5 speed the Trans is shot and a non overdrive the truck has less than 75k -on it someone was on obviously very hard on the Trans however the rest of truck has been garage kept for its entire life of each owner truck so what I want is a list of transmissions that are bolt on adaptable with an overdrive that part is a must now since I know Ford offered a zf5 In a factory 460 truck however I know there are a few different zf5 throughout the years and what would pros and cons be with the different ones and do I have to utilize a hydraulic clutch or not and what about a zf6 if possible that would be my first choice but don't think it was ever offered in a 460 so don't know about compatibility and also will the adapter plate that I now have work with anything else or just the Eaton thanks
Old 07-12-2014, 12:42 PM
Hello anyone???
Old 07-12-2014, 07:10 PM
finn finn is offline
finn is gaining momentum as a positive member of FTE.finn is gaining momentum as a positive member of FTE.
Medium duty trucks generally have SAE type bellhousings which incorporate provisions for the rear engine mounts. If I recall correctly the zf 5 speed is a light duty (F250-550) that doesn't have those mount provisions.
You need to stick with a medium duty transmission.
Old 07-12-2014, 09:38 PM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.80broncoman is gaining momentum as a positive member of FTE.
Figure out what bell you have first. then finding a replacement trans will be simpler.
post #7 of the thread below has a diagram of the SAE bellhousings.
school me on SAE 2/3 transmissions... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-19-2014, 11:11 AM
TozziWelding's Avatar
TozziWelding TozziWelding is offline
TozziWelding is starting off with a positive reputation.
There are plenty of options out there, Camoreta truck parts has them on the shelf ready to go for short money Camerota | Drivetrain specialists. Or if you want to do some digging hit up the bone yard. My F600 has a NP435 in it and they are a dime a dozen.
I'm going to do a manual swap, few last questions. Ryan313 1999 - 2003 7.3L Power Stroke Diesel 37 09-21-2016 07:17 AM
What do you know about the Eaton/Fuller 9spd hairyboxnoogle Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 64 01-15-2016 01:47 AM
OT decisions decisions Gicknordon 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 03-27-2015 01:02 PM
So many threads re: ZF5 trans swaps joegeds 1987 - 1996 F150 & Larger F-Series Trucks 3 02-10-2015 11:43 AM
Need some assistance. '95 Post-Chevy days Ranger & B-Series 2 08-09-2014 07:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
