change oil no start - Ford Truck Enthusiasts Forums
change oil no start
Old 07-11-2014, 03:30 PM
76f250highboys's Avatar
76f250highboys 76f250highboys is offline
76f250highboys is starting off with a positive reputation.
change oil no start
So the truck did start flawlessly. I changed the oil and now just cranks not even a pop. 95 power stroke.Any ideas thoughts,myths,urban legends or old wives tales?
Old 07-11-2014, 03:36 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
First question is how much oil did you put in it and did you notice anything in the oil filter housing when you pulled the filter off. Ther is a bypass valve in there that can fall out allowing all your oil to drain back to the pan
Old 07-11-2014, 03:46 PM
would the bypass valve be oblivious if I pulled the filter off to look? did not see anything when filter was off. 3 1/2 gallons of rotella almost full. This bypass valve sounds likely. is it something I can buy at a parts store?
Old 07-11-2014, 03:59 PM
It the valve a little black fella that fits in the small hole to the side? Saw that in a picture I googled. That definitely was not there when I put the new filter on
Old 07-11-2014, 04:10 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Did you search your drain bucket for it?
Old 07-11-2014, 04:12 PM
yea going to look for it now. It is special order 5-7 days out for a new one. guess I got lucky the last time I changed oil and it stayed in lol
Old 07-11-2014, 04:36 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Does the dash oil "gauge" respond after cranking for several seconds?
And of course the basics:
* WTS light?
* Tach moving while cranking?
* Any smoke from the exhaust?
Old 07-11-2014, 05:07 PM
checked oil pressure gauge while cranking and no pressure. poured 3 gal of old oil back out and cant find old valve. Not sitting in old filter either. $380 for whole new unit from ford. they dont just sell the valve. Is there a retainer clip or something to keep that valve in from falling out. Does not seem like a very good design to me if it doesn't.
Old 07-11-2014, 08:36 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Yeah if you are working on your 94 in your sig, then you have the old style that was just pressed in. The new style has a c clip. Riff Raff sells the newer style oil cooler end.
Old 07-11-2014, 10:09 PM
Thanks for the link. That is the route I will go. The Ford dealer is saying that part is no longer available.
Old 07-12-2014, 12:29 AM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
My issue is even with a new oil change there is enough oil in the resivour up top to fire it up on.it won't run long but I would think it would fire. I'm not saying the valve isn't an issue but I'm not sold on it being the whole issue.
Old 07-12-2014, 01:31 PM
Quote:
That's a good point. Did it start on the first try.
Old 07-12-2014, 03:10 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
* WTS light?
Also, answer these questions please ...
Old 07-13-2014, 10:25 AM
WTS light comes on, tach does move when cranking. did smell fuel when I cranked at first but not now. I will get the updated oil filter mount that has the bypass valve that is held in with the c clip. My guess is that this also acts as a check valve to keep pressure or at least a oil pre charge on the injectors so they will fire. Truck started and ran fine. All I did was change the oil so I just cant see it being anything else.
Old 07-13-2014, 11:44 AM
fordman67's Avatar
The "recharge" is in the hpop resivour.not anything to do with oil filter other than it is filled from lpop.
Even with no lube from the low pressure system the engine will start.
If you check the hop res and if it is low manually fill it. It should start and run for a period.
Also.check system voltage.if it drops below 10.5 during cranking it won't fire the injectors due to low voltage at the idm.
Buy the filter head but I'm not sold on that being anything but a waste of time and money.
Oil pressure guage tasilium 1994.5 - 1997 7.3L Power Stroke Diesel 5 03-10-2016 04:29 PM
Oil leak at filter?! PlainJaneTruck 1999 - 2003 7.3L Power Stroke Diesel 16 08-05-2015 01:55 PM
Oil Guage went out Resendiz Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-13-2015 06:32 AM
1993 idi oil change questions Ryan Weaver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 7 04-23-2015 10:26 AM
Changing oil filter without changing oil help! Padlock 6.0L Power Stroke Diesel 4 09-30-2014 09:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
