Slightly different blend door acuator problem
'08 150 SCREW. I had the common problem where the heat was either full hot or full cold, nothing in between. Replaced the actuator and it seemed to be good. A few weeks or months later, the actuator started chattering on startup, like it was stripping its gears. Lifetime warranty, replaced it again... and the second new actuator does exactly the same thing. (I am 100% certain I did not remove and replace the same one.)
So other than a third failed actuator, what else could the problem be?
possible explanation...
Thanks. Pulling the fuse would be a good idea, as it would save the radio presets, engine computer settings, etc, but I disconnected the battery, rendering the fuse irrelevant.
Both replacement actuators were made by Dorman; their website lists two different actuators for this vehicle. Dorman tech support says they have different actuators with the same body and connector, but different range of motion, and having the wrong one installed can cause this clicking noise as the motor tries to move the door beyond its physical limits.
I'll work with Dorman to figure out which actuator is actually correct - I'll bet a nickel it isn't the one I have installed - and we'll go from there. Stay tuned!
jdew1920
09-25-2006 07:45 AM
jvorrius
09-19-2003 09:29 AM
