transmission dipstick/ground cable -block bolt - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-10-2014, 09:45 PM
emb47 emb47 is offline
emb47 is starting off with a positive reputation.
I have lost the bolt that ties the transmission dipstick and ground cable to the back of the engine block. I called the dealer and they do not have a good illustration of the bolt and couldn't give me a size. Does anyone know what size bolt I need to get ahold of?
Old 07-11-2014, 11:41 AM
redman84's Avatar
redman84 redman84 is offline
redman84 has a good reputation on FTE.redman84 has a good reputation on FTE.
Bump. Needing the same answer...
Old 07-11-2014, 12:15 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
i have extracted 2 auto transmissions from two of my trucks (one for a part out, one for a ZF5 swap). i wouldnt be able to pick the bolt out of my can of misc truck hardware, but if you can post a picture where on the engine it goes to, i could find the hole and figure out the screw for you. then, PM me your address and i'll mail you the bolt!
Old 07-11-2014, 01:34 PM
pjwoolw's Avatar
pjwoolw pjwoolw is offline
pjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to allpjwoolw is a name known to all
Its said its the same size, tread and such, as the other transmission to engine bolts. I can't remember what size that is off the top of my head. I know I tried to find / make a different length bolt to go in there to no avail. That was the single most time consuming part of my exhaust install. The head of the bolt was larger than any hardware store bolt of the same thread / pitch. IIRC
Old 07-11-2014, 02:00 PM
quesey's Avatar
quesey quesey is offline
quesey is starting off with a positive reputation.
Think its 10 mm should be the same thread as 1 of the holes on the front of the head.
I will check to make sure in a few min
6 Volt Grounding Points Steves55 1948 - 1956 F1, F100 & Larger F-Series Trucks 13 06-08-2016 03:36 PM
idi engine grounding harnesses Ryan Weaver Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 11-21-2015 05:38 AM
'93 5.8L Engine block grounding point. rct2000 1987 - 1996 F150 & Larger F-Series Trucks 1 06-17-2015 12:09 PM
FE 390 oil dipstick tube jeff14346 1973 - 1979 F-100 & Larger F-Series Trucks 19 03-18-2015 09:57 AM
Do I need THREE Negative cables on a '79 F150 battery cable clamp? ScullyisaFox 1973 - 1979 F-100 & Larger F-Series Trucks 16 10-29-2011 11:39 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
