boost - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
boost
Old 07-10-2014, 07:27 PM
red 1997 powerstroke red 1997 powerstroke is offline
red 1997 powerstroke is starting off with a positive reputation.
boost
hi i was wondering if some one can tell what kind of boost my 97 f 350 should produce it has rose wood stage 2 injectors banks inner cooler d66 beans turbo t 500 oil pump and dp tuner when stepping on it it will get close to 30 psi then for some reason it drops 10 psi down to 20 and then my egts start climbing any body no why it be doing this? is this normal? i contacted dp tunner and they said that boost is to low and its causeing my egt readings
Old 07-10-2014, 10:24 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Boost sounds about right but when it drops to 20 I'm wondering if the boot off the turbo is collapsing?
Old 07-10-2014, 10:58 PM
boost
that is a good posability u mean the intake boot off the air cleaner? as soon as the boost drop the egts start climbing so the boost shouldnt drop that much then right?
Old 07-11-2014, 12:08 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Quote:
Do you still have the orange boot from the intake side of the turbo
Old 07-11-2014, 12:25 AM
yes i do and stock air box 2
Old 07-11-2014, 01:20 AM
fordman67's Avatar
fordman67 fordman67 is online now
fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.fordman67 has a great reputation on FTE.
Um...you need to get a riffraff intake boot and a 6637 style intake.the stock box was leak prone as well as the boot.
Old 07-11-2014, 08:08 AM
Quote:
As well as that I seem to recall reading that the orange boot can collapse on higher boost levels
Old 07-11-2014, 10:54 AM
boost
ok is there way i check to see if thats what it is, this wouldnt be a de fuel issue because the egts are getting hot right?
Old 07-11-2014, 02:44 PM
I don't think you could. You would have to see iti a loss of boost situation which I do t think you'll see parked or find anyone willing to watch while moving.
Old 07-11-2014, 02:53 PM
fordman67's Avatar
Just pull the orange boot off and take a short test driven.
Personally the orange boot is a liability regardless.they were junk new.ford sold a kit that retrofitted obs to SD style intake because it was failure prone!
Old 07-12-2014, 09:18 PM
boost
so ran the truck with orange boot off ran great boost never droped so what kind of intake should i get is the riff raff one mentioned earlier on this thread a good option? thanks luke
Old 07-12-2014, 09:41 PM
Probably one of the best. He has a great price on the filter but remember to get the turbo boot as well
Old 07-12-2014, 10:56 PM
High EGT's will not defuel but high rpm's will.
Dp tuner and wastegate actuator tube?? jstihl 1999 - 2003 7.3L Power Stroke Diesel 15 04-23-2016 08:59 AM
barely any boost with cts monitor just installed ssmokey24 1999 - 2003 7.3L Power Stroke Diesel 3 07-15-2015 08:42 AM
Boost Numbers Blue7.3 Australia Chapter 6 02-11-2015 02:44 AM
DP Infinity help, (installing EGT and other ?'s) Diesel 724 1999 - 2003 7.3L Power Stroke Diesel 12 01-21-2014 03:07 PM
boost reading on aeroforce scangauge lud04X 1994.5 - 1997 7.3L Power Stroke Diesel 16 03-08-2012 10:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
