"How-To" Install bedsides
#31
Outstanding work Brad. Looks fantastic!!
One of the benefits of bed side replacement is you can get the inner and outer panels thoroughly prepped and painted for protection. Without removing bed sides you just can't get to those inner areas.
And I noticed you did not remove the tail gate hinge mounts....
#32
The following users liked this post:
#33
I went ahead and adjusted my tail gate then jabbed it out; took many hours to get that tail aligned correctly. I let the hinge mounts be body color cause didn't think I could effective mask them off. But they look pretty good. Now no worries after final paint:
http://www.autobody101.com/forums/do...4852&mode=view
http://www.autobody101.com/forums/download/file.php?id=4851&mode=view
http://www.autobody101.com/forums/do...4856&mode=view
I carefully pulled the masking tape right after the last coat of clear.
#39
Yup this is its stock XLT twin
315/75/16 0n 16x10s
Not sure yet. But as soon as I seen it was stick, I bought it
#40
#42
This is a 5.0 w 3.55s. It has some rust but Very fixable
My buddy in CO just found me another but that is aPLAIN XL . Even has a bench seat
#43
Brad, how are those frame reinforcement pieces working out on the ccsb?
#44
I would take a 5.0 over a 4.9 any day. My brother had 96 f150 4.9/5speed with 4.10s, 33s. My bronco would KILL his truck and get better fuel milage doing it.
Plates are working good
#45
Now, about that 6.0 swap....
