Snow Plow - Ford Truck Enthusiasts Forums
2015+ F150 Discuss the 2015 Ford F150 SPONSORED BY:
Snow Plow
Old 07-10-2014, 06:09 PM
brddog brddog is offline
brddog is starting off with a positive reputation.
Snow Plow
Up til now a snow plow on a 150 will void the warranty.I heard a rumor from a salesman that the 2015's will be coming with a snow prep option.Has anybody heard anything or can tell me where to go for info.Forget the dealers around here.Thanks!
Old 07-10-2014, 06:13 PM
AlaskanEx's Avatar
AlaskanEx AlaskanEx is offline
AlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputationAlaskanEx has a superb reputation
Yes, I work for a BOSS snow plow dealer and we received info on the 2015 F-150's that will be available with a plow prep option. From what i've read they say you can only mount and run a plow on a truck with this package. It will only be available on 5.0 4x4 trucks with certain cab configurations. If i can dig up the info i have i'll post it.
Old 07-12-2014, 06:53 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Old 07-12-2014, 02:17 PM
Cool! thanks
Old 07-14-2014, 07:28 PM
Frantz Frantz is online now
Frantz has a great reputation on FTE.Frantz has a great reputation on FTE.Frantz has a great reputation on FTE.Frantz has a great reputation on FTE.Frantz has a great reputation on FTE.Frantz has a great reputation on FTE.
Link from Ford
ALL-NEW FORD F-150 ADDS TOUGH NEW SNOW PLOW PREP OPTION ACROSS ALL CAB CONFIGURATIONS
The all-new 2015 Ford F-150 is expected to be the only light duty pickup with a manufacturer’s snow plow prep option across all cab configurations*
F-150 owners with snow plow prep option can operate a plow installed via the aftermarket
Maximum light-duty plow weight will be over 450 pounds
Winter warriors will have a tough new tool in their arsenal against Mother Nature with Ford’s new snow plow prep option, available on the all-new 2015 F-150. Ford is expected to be the only manufacturer to offer a light-duty snow plow prep option across all cab configurations – Regular, SuperCab and SuperCrew.*
When snow plow mode is activated via the push of a button, the vehicle temporarily turns off nonessential features to provide dedicated power for the plow.
The option package requires the truck be equipped with a 5.0-liter V8 engine and four-wheel drive, and is available across XL, XLT and Lariat trim levels.
“The new 2015 F-150 is the toughest F-150 ever, and by using more high-strength steel in its frame and advanced materials in the body, we’ve made the new truck up to 700 pounds lighter,” said Eric Peterson, Ford F-150 marketing manager. “This leads to more capability and better handling, which is exactly what you’d want for plowing. Adding a snow plow prep kit to our lineup helps ensure our customers have even more tools at their disposal to get the job done.”
Upon taking delivery of a new F-150 with the snow plow prep option, owners will need to take their truck to a Ford Qualified Vehicle Modifier to purchase and install the plow hardware. The maximum light-duty plow weight will be over 450 pounds.
Pricing for the snow plow prep option, excluding the plow, will be announced later this year. The all-new 2015 F-150 will arrive in dealerships at the end of 2014.
* When properly equipped. Class is Full-Size Pickups under 8,500 lbs. GVWR.
Old 10-06-2014, 07:52 AM
GetMore GetMore is offline
GetMore is starting off with a positive reputation.
Turns off an "nonessential features"?
I wonder what that really means.
Old 10-07-2014, 01:43 PM
tvsjr tvsjr is offline
tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.tvsjr has a great reputation on FTE.
The big concern with these trucks is electrical load. I would expect the button to disable anything that draws substantial power but isn't critical... stereo, etc.
Old 10-07-2014, 11:48 PM
Frdtrkrul Frdtrkrul is online now
Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.Frdtrkrul has a good reputation on FTE.
I think the plow package turns off any nonessential electronic to help compensate for the snow plow. At least that's what I read several months ago when they had first announced it. I think the only F150 that was rated for a snow plow was the 7700 7 lug from a decade ago. One problem that Ford NEEDS to address is adequet engine cooling when the snow plow is in full use and when it is fully up in front of the radiator. At my dad's work they had a 1994 F250 351W with an 8 foot Western snow plow and if the blade was up it had to be turned either left or right to allow more air to flow through the radiator other wise the truck will over heat. Not sure how radiators have changed in the past 20 years or how much the size difference is between a fuel injected 351 Windsor radiator and the current 5.0L Coyote, but its something Ford cannot afford to ignore.
Old 10-12-2014, 03:59 PM
Anomic Anomic is offline
Anomic is starting off with a positive reputation.
Interesting its not available with the 3.5.....
Old 10-14-2014, 09:04 PM
jntibs jntibs is offline
jntibs is starting off with a positive reputation.
I don't understand the plow button nonsense. Why not just add a battery and/or alternator to compensate for electrical load?
Old 10-15-2014, 12:20 AM
Batteries add weight and significant complexity (especially if you aren't just paralleling them). Bigger alternators are more expensive and cause more engine drag.
Old 10-15-2014, 07:56 AM
Still seems like a simpler solution than turning off nonessential stuff to me.
Old 10-15-2014, 05:42 PM
Not really. With everything operating off CANBUS these days, turning off the nonessential stuff is a matter of sending a few messages on the network. For instance, did you know there is no longer any switched power to the stereo system? It's powered all the time, with off and on being controlled by CANBUS.
Old 10-24-2014, 01:54 AM
thzpcs thzpcs is offline
thzpcs is gaining momentum as a positive member of FTE.
It's pretty cool that they are offering a pre-plow prepped F-150. I know that being a plow truck completely destroys most trucks, so it's nice to see Ford responding to demand.
Old 10-24-2014, 09:28 PM
fordman19762003's Avatar
fordman19762003 fordman19762003 is offline
fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.fordman19762003 has a very good reputation on FTE.
the non essential stuff might also be traction control, RSC, etc.
Snow Plow Package - whats in it? Shernius 1999 to 2016 Super Duty 11 08-06-2015 05:42 PM
Western Snow Plow Plumberdude3 1999 to 2016 Super Duty 2 04-04-2015 06:54 AM
Snow Plow? Restlesswildman Excursion - King of SUVs 17 03-05-2015 10:41 PM
Snow Plow - Warranty VOID ???? cgoleye 6.0L Power Stroke Diesel 9 09-23-2004 09:47 PM
Snow Plow Pump Pastmaster 1999 to 2016 Super Duty 6 09-26-2002 08:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
