Anyone know of a good rebuild manual for Ford axles? - Ford Truck Enthusiasts Forums
Old 07-10-2014, 05:41 PM
Ranger Bob Ranger Bob is offline
Ranger Bob is gaining momentum as a positive member of FTE.
I would like to rebuild the rear axle on my 2005 F-150.
Axle Model V-953-J, 9.75" ring gear, 3:73 ratio, limited slip.
I have never attempted this or even watched it other than a few videos. Tools, not a problem! I don't doubt that I'm capable of doing it. I just don't have the confidence to attempt it without a very good manual.
Any suggestions that would cover this axle will be greatly appreciated!!
Old 07-12-2014, 04:59 PM
Nothing??
Old 07-12-2014, 10:28 PM
rander101 rander101 is offline
rander101 is starting off with a positive reputation.
Check out the Chilton and/or Haynes manuals for your truck. You can find them at most book stores, some auto parts houses sell them and you can get them online. Probably the best is the Ford Service Manual from Ford Motor Company. Helm Publishing sells them and they are very detailed about every job but they are expensive -- on the order of $150 for a full 3 volume set.
Old 07-13-2014, 05:59 AM
The chilton/haynes only give basics on how to repair/replace axle bearing or axle shaft. They avoid the specifics on setting up a differential because it's for advanced skill level. "should be performed by professionals"
The FMC Service Manual is probably my best bet, but for now I have talked myself out of doing the rebuild AGAIN!
We'll see what the bearing replacement accomplishes.
TTB D50 axle seals HeavyE85 1987 - 1996 F150 & Larger F-Series Trucks 1 10-31-2016 10:54 PM
No 4x4 Help diagnosing Manual Hub questions? Spitfire0450 1999 - 2003 7.3L Power Stroke Diesel 12 01-28-2016 01:46 AM
Axle rebuild kit InmatesRunThePlace Excursion - King of SUVs 2 02-13-2015 07:44 PM
2004 Differential noise fix! bigbluetruck Explorer, Sport Trac, Mountaineer & Aviator 9 12-21-2010 05:27 PM
where to get ford shop manuals? buck_ 1987 - 1996 F150 & Larger F-Series Trucks 13 07-25-2010 06:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
