Rookie in San Diego
Look in your owner manual beginning page 165 under towing.
Pick out your trucks equipage for engine size, gear ratio and transmission.
First see total gross combined weight, then the trailer weight.
For example page 168 for 5.4L, 3:55 & the 16 inch tire size axle ratio, automatic transmission.
Max gross combined weight is 13,000 lbs.
Subtract your trucks loaded weight that means passengers, full tank of gas and anything else from 13,000 and you have your total legal "loaded" trailer weight.
Don't just go with the trailer weight given because you could go, over the max GCWR of 13,000 lbs.
Good luck.
Good luck.
AKHunter93
27
05-09-2016 04:42 AM
saysay
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
11-29-2005 10:24 AM
2003150
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
09-28-2004 01:26 PM
