REAR AXLE QUESTION!! - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 07-29-2014, 09:48 AM
Ranger Bob Ranger Bob is offline
Ranger Bob is gaining momentum as a positive member of FTE.
I did a lot of research to get the best price on (in my opinion) high quality parts. Timken bearings all made in USA except one, a Canook. I just added all my receipts. The total is $315.00 That includes all 6 bearing sets, 3 seals, oil slinger, nut, shim kit, FMC oil, friction modifier, RTV, I'm sure I'm missing something.
The pro, most likely, would have charged more for parts. He is in business to make money! That leaves very little of the $600 - $700 for labor. My final cost to have the pro do it probably would have been closer to $900. Make me feel better about taking this on.
  #47
Old 07-29-2014, 10:04 AM
Mr CMK
Yeah but it could have went south in a hurry! If the gears were new it would have made this a lot more difficult do to different shim set up on pinion and RG. A lot more adjusting shims and checking patterns. So yes, my project wasn't so bad.
Thanks to all that helped and gave support!
  #48
Old 07-29-2014, 08:25 PM
70f100longbed's Avatar
70f100longbed 70f100longbed is offline
70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.70f100longbed has a very good reputation on FTE.
I'm glad you got it together and it has no noise. The next one will go much smoother. FYI, to fill the diff easily, remove the ABS speed sensor at the top of the housing and pour the fluid in there.
  #49
Old 07-29-2014, 10:29 PM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
Quote:
That's a good tip ,..but the last time I filled mine , the oil I bought came in this real thin flexy bottle , that you squeezed like a tube of tooth paste , and it was simple to fill it .
  #50
Old 08-03-2014, 08:06 AM
Have about 400 miles now. All different types of driving but been taking it easy from a stop. Still no noise and still gets warm/hot at pinion bearing.
Great tip on the speed sensor! The breather did not work as well as I thought.
Gear oil question: I did not replace the gears so do I need to change the gear oil after few hundred miles or not? I got the impression the oil change was for the phosphorus on the new gears and the metal from new gears seating. All I added was bearings so I'm thinking the $50 dollars can be saved. ADVICE??
  #51
Old 08-03-2014, 08:34 PM
No need to change the oil again.
Rear axle swap in Excursion, different lengths? blloyd29 1999 to 2016 Super Duty 1 03-28-2016 08:11 PM
Took a picture of the Differential Tag. Help me figure it out. (PIC) Seven11 1997-2006 Expedition & Navigator 6 02-24-2016 11:55 PM
Rear differential waldreps 2004 - 2008 F150 14 08-23-2015 11:34 AM
limited slip spider gears 9.75 ramair428cjxr7 1997 - 2003 F150 0 03-16-2015 06:10 PM
Anyone know of a good rebuild manual for Ford axles? Ranger Bob 2004 - 2008 F150 3 07-13-2014 05:59 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
