3 and 4 injector not firing when warm above idle.
07-09-2014, 10:42 PM
on
Need help 3 and 4 injector quits firing when truck warms up and is above idle. I pulled both injectors and sent them in to be fixed and there wasn't anything wrong with them. The UVCH looks good on both sides. I don't know what it could be any help would be great thanks.
07-10-2014, 05:43 AM
What do the outer vc pins/connections look like? I'd check the wires all the way from the injectors to the idm for breaks too.
07-10-2014, 07:13 AM
Take the IDM out and shake it to see if you can hear any water in there.
07-10-2014, 04:57 PM
on
I will check all the wires and the IDM sat morning when i put it back together. I hope it is one of those two things.
07-15-2014, 10:39 PM
on
I got it fixed! My chip was causing it,pulled it off and scotch brited the connections and put it back together and it runs great now.
07-16-2014, 05:30 AM
Good to hear. That should always be the first step, removing the chip. You should have mentioned you had one. No big deal, glad its going.
robbiebrown25
08-15-2013 06:30 AM
sdunn9
02-18-2011 05:17 PM
TransplantX
11-29-2008 05:05 PM
polcat
10-03-2008 09:12 PM
blrman1962
05-28-2007 06:13 AM
