3 and 4 injector not firing when warm above idle. - Ford Truck Enthusiasts Forums
Old 07-09-2014, 11:42 PM
BLK 96 BLK 96 is offline
BLK 96 is starting off with a positive reputation.
Need help 3 and 4 injector quits firing when truck warms up and is above idle. I pulled both injectors and sent them in to be fixed and there wasn't anything wrong with them. The UVCH looks good on both sides. I don't know what it could be any help would be great thanks.
Old 07-10-2014, 06:43 AM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
What do the outer vc pins/connections look like? I'd check the wires all the way from the injectors to the idm for breaks too.
Old 07-10-2014, 08:13 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Take the IDM out and shake it to see if you can hear any water in there.
Old 07-10-2014, 05:57 PM
I will check all the wires and the IDM sat morning when i put it back together. I hope it is one of those two things.
Old 07-15-2014, 11:39 PM
I got it fixed! My chip was causing it,pulled it off and scotch brited the connections and put it back together and it runs great now.
Old 07-16-2014, 06:30 AM
Good to hear. That should always be the first step, removing the chip. You should have mentioned you had one. No big deal, glad its going.
Injector out? help fordguy390 1994.5 - 1997 7.3L Power Stroke Diesel 19 11-27-2016 10:24 PM
Wont start unless plugged in. Injectors? GDSchafer 1999 - 2003 7.3L Power Stroke Diesel 12 05-14-2015 04:31 PM
Won't start injectors not firing, runs rich when started Magnum199944 1987 - 1996 F150 & Larger F-Series Trucks 10 03-09-2014 08:02 PM
My 05 6.0L runs rough when cold. WhiteBeast-05-powers 6.0L Power Stroke Diesel 15 11-09-2013 01:47 PM
Unloading white smoke @ 2000 rpm, 1st and 2nd svcguy 1994.5 - 1997 7.3L Power Stroke Diesel 17 02-05-2012 11:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
