Replacing transmission. - Ford Truck Enthusiasts Forums
Old 07-09-2014, 09:15 PM
CDone CDone is offline
CDone is starting off with a positive reputation.
Ok got the word from the dealership today that my transmission is toast and need to be replaced. After I picked my jaw up off the floor from the quote I got ($5000 to $7000 all in), I'm wondering what a new tranny should cost me in the real world (outside of the dealership). Can anyone give me an idea? Plan is to call a couple shops over the next few days but I don't want to go in without a clue.
thanks
Colin
Old 07-09-2014, 10:03 PM
CaptFX4 CaptFX4 is offline
CaptFX4 is gaining momentum as a positive member of FTE.
Quote:
thanks
Colin
Wow. Where are you located? That seems excessively high. Depending on what you get, rebuilt, new etc, you should be in the $2000 -$3500 range. Some use jasper trannys so ask around about those.
I think the stearlership is taking you for a ride on this.
Old 07-10-2014, 10:03 AM
ojai150 ojai150 is offline
ojai150 is starting off with a positive reputation.
They are trying to totally screw you ,...you should be paying between $2000 -$2800
for a total warranted rebuild with a new torque converter.
What was it doing / not doing , that you need a rebuild ??
Old 07-10-2014, 09:04 PM
They are trying to tell me its been running without fluid for a while and has burned up all the insides (funny considering it gets in for regular servicing at the dealership). I'm already into it for over $1000 just to have them look at it (7hrs @$150 per hour) and then they want $5000 for the tranny and more labour and parts on top of that, in the end probably well over $7000, hard to justify on a vehicle that might get $5000 on a trade-in.
Waiting to hear back from Ford Financing to see if they can put us into a new truck.
Colin
Old 07-10-2014, 11:07 PM
Colin
$1000 just to look at it ? What is the flat rate for simply removing the transmission ?
Old 07-11-2014, 10:03 AM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Colin
The problem with that theory is, when the fluid gets too low, the truck won't move, so there's no way you can drive it when the fluid gets too low. I probably would have found a used trans and had it installed.
Old 07-12-2014, 08:06 PM
easier fix, just bought a 2011 F150 XTR with only 46000 KM's on it. Guess its time to move up the sub-forum list
Thanks All
Colin
Old 07-12-2014, 08:15 PM
Thanks All
Colin
Sounds like the dealer got you right into the position they wanted you,
how much did they give you for a truck that needed $7000 worth of work ?
Old 07-15-2014, 10:43 AM
actually it was a different dealership, they covered the outstanding balance, plus a little extra, and took very good care of us. Will not return to the original dealership ever again, second dealership couldn't believe that the sales dept. never even tried to contact me, oh well their loss.
Colin
Old 07-15-2014, 03:12 PM
Colin
Wow ,...a good luck story ,..
Old 07-16-2014, 04:40 PM
tjcprop's Avatar
tjcprop tjcprop is offline
tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.tjcprop has a very good reputation on FTE.
Just replaced my transmission at a price of $4500. Shop "beefed" it up to accomodate for larger wheels, gears, etc.
Help! Truck Shuts down randomly imohring 1999 to 2016 Super Duty 10 11-09-2015 03:49 PM
2010 F150 Oil Leak Leslie Alford 2009 - 2014 F150 9 10-26-2015 09:32 AM
Problems if hubs were left locked? KodiakF250 1999 to 2016 Super Duty 5 10-22-2015 04:37 PM
2004 F-250 Transmission Fluid Temp Sensor Phillip Vega 6.0L Power Stroke Diesel 10 06-01-2015 04:23 PM
Transmission Fluid Temperature Sensor Phillip Vega 1999 to 2016 Super Duty 1 04-10-2011 06:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
