Headlights shut off?
Hello again.
Just last night I was fiddling around with the truck (71' f250 2WD auto w/390) getting it ready for inspection and I turned the headlights on to go around the block. It was fine but when I pulled back into the driveway I was just letting it idle for a bit and the headlights just shut off and then the dash lights shut off shortly after. I turned the switch off and on a bunch of times and the dash lights come on like they should but now the headlights wont come on.
Any ideas?
Any ideas?
Alright...I figure it out....And I feel a little silly. I got in the truck to move it and i just barely bumped the hi/low switch on the floor and the headlights kicked on! There must just be a sweet spot that makes them turn off but its pretty hard to find so it wont happen very often. Im glad it wasnt a wiring issue!
on
Yup this was a common problem with all the bumps. And if it has not happen to you already then wait it will.
1.The Head Light switch failures
2.The high & low beam switch fails b
3.The head light wiring loom in the eng. bay fails from moisture.
4. head light bulb socket bad.
These are all things that can happen just to the head lights.
Orich
Orich
Orich
Orich
