Dana 60 Crossover Steering Shock Relocation
Just curious what you guys that are running crossover steering did for the lower shock mount on the passenger side (relocation to the rear of the axle)?
I would like to retain the "stud" style mount since I'm only running 4" superduty springs. I thought about either fabbing a mount, the same design as the driver's side, or just trying to find another driver's side mount in a junkyard to use.
Any help is much appreciated....
BTW, your Supercab is a good looking ride.
Love your truck Fordrealdrive!
Mine had to be moved with the WFO stuff.
Just an FYI on the WFO stuff rod ends. You might want to let them know it's for a heavier truck. The first set of rod ends were junk out of the box and they sent me a heavier duty version the second go. He didn't say much about it, but I speculated the standard stuff is good enough for a lightweight Jeep but my heavy a$$ rig they felt an upgrade was a good move. I had to cut the drag link down further because the drivers side was longer.
Well, I apologize if I steered anyone the wrong way lol!
I'm not familiar with the wfo arms, but my nwf arm measures 8" from kingpin centerline to drag link C/L and has the hi-steer tie rod mount at 4 3/4" from kingpin C/L . My drag link lines up almost right over the top of the tie rod and clears the shock by close to 2.5".
Wheels straight
Turned right
Turned left
Drag link in line with tie rod
Clearance between X-member and drag link
I looked for a long time before deciding on my x-over steer and my requirements were:
No shock relocation
No welded steer links and must use TRE'S
Steer arm must be machined with a rise for leaf clearance
Options for 5th knuckle bolt and hi-steer mount
Wheels straight
Turned right
Turned left
No shock relocation
With the northwest fabs kit, I had to trim close to 1.25" off of my threaded DOM tube iirc.
alaskaforby4
09-11-2009 03:09 PM
alaskaforby4
09-11-2009 02:27 PM
