Cab clearance lights - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-09-2014, 12:15 AM
jle70's Avatar
jle70 jle70 is offline
jle70 is starting off with a positive reputation.
Opinion: What is best? All 5 lights evenly spaced or outer 2 with 3 in center?
Question: What is standard mounting measurements for both? (I don't want to guess)
Old 07-09-2014, 12:37 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
If your installing them look at some picks and decide what you like best. I personally like the evened out
Old 07-09-2014, 12:39 AM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
Evenly spaced. Not sure on measurements.
Old 07-09-2014, 12:58 AM
jle70's Avatar
I just put some on my sons Bronco evenly spaced. They look good. But most trucks you see the side markers with the three center clearance.
I kinda like the evenly spaced. But more opinions the better.
Thanks
Old 07-09-2014, 07:30 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
The stock lights were evenly spaced from the factory. The newer truck have them spaced out unevenly, but the older ones like we have were all spaced the same from the factory. If I recall correctly when I put them on my old truck I spaced them on 12" centers and 1 5/8" back from the drip rail. Here is a thread that has the how-to. Page 2 has the measurements.
Old 07-09-2014, 10:49 AM
jchosler's Avatar
jchosler jchosler is offline
jchosler is starting off with a positive reputation.
Evenly spaced for sure
Old 07-09-2014, 04:53 PM
jle70's Avatar
So far these are what I have got from scouring internet for standard light placement:
3 Lights centered
Lights Centered
Old 07-09-2014, 05:10 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Go with even spacing. 3-in-the-center makes me think chevy...
Old 07-09-2014, 11:28 PM
jle70's Avatar
Agreed. Even spacing it us. So I have read that there is a factory connector in passenger kick panel for the lights. True?
Old 07-09-2014, 11:31 PM
jle70's Avatar
And I assume everyone's follows the arch of cab, not in straight line?
Old 07-09-2014, 11:50 PM
williameub williameub is offline
williameub is starting off with a positive reputation.
Quote:
Yup. Pull it out and it stares you in the face. Can't miss it.
Old 07-11-2014, 10:12 AM
jle70's Avatar
Thanks. Now I just need to get them on. :-)
Old 07-11-2014, 01:26 PM
...and post before and after pics!
Old 07-12-2014, 10:15 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Evenly spaced like the factory did it
http://www.ford-trucks.com/forums/11...ab-lights.html
no brake lights jawdoc 1999 to 2016 Super Duty 19 11-13-2015 03:17 PM
Right side tail light and marker light not working hath 1967 - 1972 F-100 & Larger F-Series Trucks 1 11-01-2015 01:08 PM
What do they call this set of lights STEVES68NOVA 1999 to 2016 Super Duty 12 04-02-2015 12:14 AM
6-volt backup lights jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-24-2014 06:36 AM
1987 F350 Reverse lights troupstree 1987 - 1996 F150 & Larger F-Series Trucks 12 07-07-2014 12:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
