Towing with a 2v
Towing with a 2v
I have an '03 F250 4x4 SCLB. I just bought a 31' 5R. It weighs 13k loaded. Here's the deal: I have 3:73 gears.. I haven't installed the hitch yet. Do you think I'll be ok pulling the trailer up over 7k mountain passes, or will I have to upgrade to 4:56 gears? I didn't like the way it pulled my 4k BP in Colorado and am very concerned about yanking three times the weight. I'd been threatening to change to a diesel, and the PO of the trailer is willing to swap his 2000 PSD straight across with me. Mine is a Lariet with 104k on it and his is an XLT with 91k (2WD). Which makes more sense to you? Appreciate any input; thanks.
My EX with 3.73s was a dog pulling our 9.5K toyhauler, swapped out for 4.88s and it was a locomotive! Ate up hills like they weren't even there! I'm now pulling an 11K TT and running 35" rubber for an effective ratio of 4.39, still a great tow rig, been up and down everything the East has to offer with no complaints.
Get the gears.
I would also recommend some tunes from Mike at 5 Star, Y-pipe or headers and Y if you want to get the most from the 6.8 2V.
Get the gears.
According to Ford's towing guide, your truck is rated to tow 10,800 pounds. 12,500 if you had 4.30 gears. A gear swap seems necessary. I would also do the header/exhaust mods and a 6.0 tranny cooler swap.
Page 19
https://www.fleet.ford.com/resources...s/2003_All.pdf
Page 19
Yeah you will want the 4:56s to tow that weight especially at higher altitudes.( 6.0l tranny cooler is a must too imo) However with thinner air at higher altitudes the 7.3l will have the advantage do to being forced induction. As the air gets thinner a naturally aspirated engines looses more power than a forced induction engine.
I just bought my 2010 V10 to replace a 2000 7.3. Bone stock the V10 is a better daily driver. Even with a 60hp towing tune from the Edge Evolution, I didn't think the 7.3 was that hot-**** towing my 33' 5er around Albuquerque. Oh yeah, if the injectors go out, they're $3,000 a set......if you do the work yourself. A shop will charge you $1,500 to do it for you. I work alot of hours and don't have time to fix my own vehicles (except for oil changes & small stuff), and I can't afford the diesel that I don't need every day. My 2000 is an XLT 2WD also, and I don't have much interest from buyers around here, everyone wants a 4wd.
Thanks
Thanks for your input! I did have the 6.0 cooler installed. Also installed air bags and compressor. Bought tunes from Mike; wow..really woke it up. I also had the y pipe changed out. It has more low end power but has changed out the drone for the dreaded flutter at nearly the same rpm range. Hate it. .The shop that installed the pipe recommended drilling and welding a bolt into the y union to change the flow. He's had good results with other rigs. Anyone else tried that?
