Need a new key made - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Need a new key made
Old 07-08-2014, 11:55 PM
marcogyver marcogyver is offline
marcogyver is starting off with a positive reputation.
Need a new key made
Never did I think I would be posting about a new key but I can't believe the dealer want $140 for a new key cut and programmed, this is without the FOB. I have my original key but it was dropped and run over so the security chip doesn't work. Has anyone purchase else where such as ebay and had a locksmith cut it? I would image this is less expensive and programming shouldn't be difficult if I still have one working key.
Any advice or experiences are appreciated.
Old 07-09-2014, 06:54 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Call your locksmith and ask him.
If you don't have one working key, you only have two options: Dealer or locksmith. Get TWO keys made and programmed in. Make sure they are not identical (one cloned from the other).
Once you have two working, unique keys, you can by the blanks off eBay, cut them locally, and then program into the system yourself.
Old 07-09-2014, 08:20 AM
SinatraFan SinatraFan is offline
SinatraFan is starting off with a positive reputation.
I just went through a key scenario myself. apparently, the keys I had with the car were cut by the idiots at the dealer lot I bought it from and they wouldn't open the drivers door. I always used the FOB to unlock the door but the battery died one morning only to find out the keys didn't work. Well... after finally finding a good locksmith that wasnt a crook, I still paid nearly $200 to have 2 keys cut and programmed and a key/fob cut and programmed including parts and the service call to my home. Total, 3 keys and one fob so that wasn't too bad
here's the key/fob i was referring to.
Just make sure you get them to commit to a price UP FRONT.... don't let them scam you into a BS answer and all of a sudden you're sitting on a huge bill.
Old 07-13-2014, 08:03 AM
Thanks, a buddy referred a locksmith to me that does work for dealers. He said 80 buck which isn't so terrible. I found a way around my issue for now. I have an aftermarket alarm/remote start. I remote start the vehicle which bypasses the PATS so I can use my broken PATS key.
Old 07-13-2014, 12:32 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
I take it you don't have a second key?
Old 07-13-2014, 02:54 PM
Quote:
I do have one good working PATS key and one FOB but from what I read on a 2002 you need 2 working keys to program with out a programmer.
Old 07-13-2014, 03:29 PM
If you have a remote starter installed, you may have a pre-programmed key tucked away up under the dash in a key bypass module (or your might have an module that imitates a key).
Old 07-13-2014, 03:31 PM
You should have said that in the first place, as well as having a working remote starter.
An existing, working PATS key can be cloned for about $60 at Home Depot. It will keep you on the road and out of trouble, but you won't be able to program in new, unique keys (see my previous post).
Old 07-13-2014, 05:22 PM
Quote:
Originally Posted by projectSHO89 View Post
If you have a remote starter installed, you may have a pre-programmed key tucked away up under the dash in a key bypass module.
Yep, that's where I was heading. If there is a key up under the dash, plus the spare in-hand, that gives two key heads in order to program in a new third one without going to a dealer or locksmith.
Old 07-13-2014, 09:48 PM
Thanks for you help. I'll have to look around under dash. I looked briefly but didn't see anything like that but have to fish more.
Old 07-24-2014, 09:07 PM
Thanks for the help. What I've found out is there is a DEI 551t remote starter and 555F transponder. The transponder is mounted up inside the column by the key lock and was programmed with the PATS info. The locksmith made/programmed two keys and one valet for 100 buck which is I think is very good considering dealer wanted 160 for one.
Now I just need to figure out how to program the FOB. My alarm is using the factory FOBs and must be bypassing the control module or igintion system because I can't enter the programming mode.
Old 07-24-2014, 09:14 PM
Quote:
What's the make and model number of your alarm?
Old 07-24-2014, 11:01 PM
It's an automate 415.
Old 07-24-2014, 11:12 PM
In that case start by finding the valet button.
-Turn the key on
-Press and release the valet button once and then press it again but hold it this time.
-While holding valet button, press the lock button on remote and light/horn will sound.
If that happened you are done and the remote is now programmed in, if not try again by starting over from beginning.
Old 07-25-2014, 10:16 PM
Thanks for the suggestion. I was hoping that would work but the research I did looks like my FOB is communicating with the Expy lock system and not with the automate. The automate is just using the lock pulsed to activate.
Inexpensive replacement key solution. pirate4x4_camo Excursion - King of SUVs 16 02-11-2016 05:05 PM
PATS Ignition Key Programing Question banshee_man_96 Excursion - King of SUVs 45 10-25-2014 12:27 PM
PATS key question JF94 1997 - 2003 F150 4 08-19-2010 07:35 AM
PATS key sharing? jas88 1997 - 2003 F150 24 06-22-2009 04:01 PM
PATS key work around? cobrarep Excursion - King of SUVs 12 08-03-2008 02:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
