Systems 101: Designing a Custom Exhaust System for Your Truck - Page 2 - Ford Truck Enthusiasts Forums
Old 08-04-2014, 12:31 PM
makthenif's Avatar
makthenif makthenif is offline
makthenif is starting off with a positive reputation.
Quote:
Originally Posted by Matt@Flowmaster View Post
You may want to direct your question to a representative of the brand of muffler that you are planning to run. They should be able to give you a better idea of how to set your system up in relation to their products. Good luck!
I am asking for an opinion on the design not the muffler. Frankly I am undecided on the muffler. So if you are unwilling to comment on the design I understand. Thanks
Old 08-04-2014, 01:41 PM
Matt@Flowmaster Matt@Flowmaster is offline
Former Vendor
Matt@Flowmaster is starting off with a positive reputation.
Quote:
I am here to help. I was simply stating that I could not provide you with the proper information in relation to sound or performance, that you are looking to achieve, based on a product that I am not familiar with incorporating into a system.
What vehicle are you designing your system for? Please let me know the model, year, engine and current exhaust setup (ie: is it still stock, what diameter tubing if it was altered, etc.).
Old 08-07-2014, 01:26 AM
351Cleveland C4's Avatar
351Cleveland C4 351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
Hey Matt, what do you think about this?
I have a 71 f-100 with a 351 cleveland engine. Nothing too hot, just edelbrock carb intake and cam.
Right now it has 2" dual off of stock manifolds, 22" glasspacks.
I like the way it sounds, but am wondering if the 2" pipes are flowing enough for ideal performance. The engine will never get revved above 5,500 rpm.
It's a daily driver, with some towing/hauling duty, and a lot of haul-*** duty. Basically my do everything pickup.
I would want it to sound aggressive and loud at the tail pipes, but keep quiet and mellow while cruising. The current system does a good job at that, but could be a little louder.
Here is a YouTube video I made of it.
Old 08-07-2014, 12:01 PM
Former Vendor
I'm pretty sure that stock tubing on your truck was 2.25" from the factory but considering your mods and the size of your engine, you definitely need to be running 2.50" pipes. As far as sound, those glasspacks will get louder as the packing material wears down, but I would recommend a pair of our 50 Series Delta Flow mufflers. Be sure to add an H-pipe to your system to get an even deeper tone and increase a little bit of that low-end torque.
Old 08-07-2014, 12:24 PM
Thanks Matt, I'll do just that when I build it.
Old 08-07-2014, 12:28 PM
Former Vendor
No problem. Best of luck to you! Let me know if you have any more questions once you get moving on this.
Old 08-07-2014, 03:11 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Matt,
Does Flowmaster offer any type of system to replace the stock exhaust on a 1986 F150 SWB with 4.9L six cylinder, from the exhaust manifold back? The engine is stock other than having been converted to Duraspark ignition with recurved distributor. It still has the original 2 catalytic convertors, but no EGR or air pump.
My tastes are more towards the mellow sound, not too loud, but perhaps a little more free flowing.
Thanks!
Old 08-11-2014, 11:45 AM
Former Vendor
Quote:
Originally Posted by 1986F150six View Post
Matt,
Thanks!
Unfortunately, Flowmaster does not produce a direct fit Cat-back system for your truck. However, we do offer several muffler options for you application. Let me know if you have any other questions.
Old 08-11-2014, 11:50 AM
Thank you!
Old 08-19-2014, 09:25 AM
Trlrdrinla Trlrdrinla is offline
Trlrdrinla is starting off with a positive reputation.
Matt,
I have 2011 f250 6.2. I have a CAI on the way and I want to do some exhaust mods for sound, power and economy. I have read a lot of post where there was a loss of mileage and power when exhaust mods are made. I believe the correct mods can help both power and economy. What would you recommend for this truck, cat back system or a few parts changed out? I also run the 87 performance/tow tune from five star. This is a weekend driver, 70% towing a four horse trailer or tractor.
Old 08-19-2014, 01:04 PM
Former Vendor
Quote:
Originally Posted by Trlrdrinla View Post
Matt,
I would recommend Flowmaster part #817505 because it is a fully engineered system that was designed specifically for your vehicle application. This Flowmaster Force II kit comes with two sets of tail pipes. The provided tail pipes allow for either a rear exit or side exit exhaust setup. Because you use your truck for towing, I would use the side exit pipes so that the sound won't be bouncing back off of your horse trailer.
Old 08-20-2014, 08:17 PM
acc2828 acc2828 is offline
acc2828 is starting off with a positive reputation.
does the overall length matter
Matt
I was thinking of coming out in front of the rear axle. I have a 77 4x4 shortbox. And I was thinking of mimicking my 97 f150 that had the exhaust come out in front of the rear wheels. Will this hinder performance.
  #28
Old 08-21-2014, 10:52 AM
Former Vendor
Quote:
Originally Posted by acc2828 View Post
Matt
You should be fine as long as you are able to run an adequate amount of tail pipe, at least 12 inches, after the muffler.
  #29
Old 10-20-2014, 08:07 PM
docbar85 docbar85 is offline
docbar85 is starting off with a positive reputation.
Matt
I have a 1990, F250, 351 that has a crack in the drivers side exhaust manifold.
Considering I got to replace the manifold I'm thinking about putting headers on it to maybe get a little more HP, MPG. Keep in mind I am completely open minded as to what would be best. I could just replace the manifold, or install headers and hook it up to what I have, or put headers on it and replace everything, or replace the manifold and change everything else. The air pump has been removed and the ports on top of the manifold have been plugged. As far as sound goes I don't care for anything loud but I want to easily hear it running. I would prefer to have duels coming out the back but it doesn't matter much. It looks like it be a little difficult getting one of the exhaust back over to to the other side. So again, the pipes can come out wherever would be best. Also, I don't mind if I need to get a muffler shop to do some of the work, especially when it comes to any bending. Please give me your opinion as to what would be best and maybe a recommendation as to which headers would most likely fit with out hammering and bending. Thanks, look forward to your reply.
  #30
Old 10-21-2014, 01:28 PM
Former Vendor
Quote:
Originally Posted by docbar85 View Post
Matt
PM sent. Let me know if you have any questions. Good luck!
Who is running Flowmaster mufflers on their Ford Truck? Matt@Flowmaster General Automotive Discussion 10 01-12-2016 12:56 PM
FTE resonator bleeds blue 1999 - 2003 7.3L Power Stroke Diesel 32 03-17-2015 01:59 PM
Replacement exhaust parts and components for an effective repair carid Vendor Specials, Discounts, Product Announcements & Group Buys 0 03-17-2015 09:14 AM
Performance Y pipe BEAST428 Modular V10 (6.8l) 9 09-27-2012 01:04 AM
F-100 Parts Links and Other Info... Deebo54 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 01-21-2006 09:29 PM
Tags
custom, exhaust, flowmaster, muffler, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
