5.4l Clunking at idle, driving fine at road speeds... - Page 2 - Ford Truck Enthusiasts Forums
Old 07-16-2014, 01:13 AM
twodogz twodogz is offline
twodogz is starting off with a positive reputation.
Like everyone else, I suggest fixing the timing problem. If you still have issues, try disconnecting the battery and then disconnecting the wiring bundle that contains the engine management wires (the one closest to the passenger side firewall on my truck) and check for water intrusion. I had this same problem last week and when I went to chase wires for continuity, I found the PCM connector was full of water (after spending a couple of hundred on parts). Also, faulty grounds may cause this type of problem. Remove and clean all grounds between the engine and the chassis. Last, before getting into spending money on parts that may be unnecessary, get a multimeter and check continuity from the PCM connectors to the sensors. Good luck, I hope my experience helps.
2005 Expedition 5.4 - Rough Idle htodac Modular V8 (4.6L, 5.4L) 2 12-29-2016 01:25 PM
P2196 and P0171 Codes cant figure out jeremymsmyth 1997-2006 Expedition & Navigator 1 08-13-2016 11:29 PM
New Injectors causing rich condition tcwilson 1997-2006 Expedition & Navigator 4 08-25-2014 03:40 PM
03 Explorer P2196 & P0405 Code Question wiwillis1980 Explorer, Sport Trac, Mountaineer & Aviator 1 06-22-2014 06:22 PM
2004 5.4 expedition p2196 camcam 1997-2006 Expedition & Navigator 4 09-28-2013 07:41 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
