LOL epa says rolling coal is illegal - Ford Truck Enthusiasts Forums
Closed Thread
Old 07-08-2014, 05:51 PM
Ken_C's Avatar
Ken_C Ken_C is offline
Ken_C is gaining momentum as a positive member of FTE.
Old 07-08-2014, 09:18 PM
Robbieo11's Avatar
Robbieo11 Robbieo11 is offline
Robbieo11 is starting off with a positive reputation.
Wtf they are protecting us from ourselves we are blinded by all the coal.
Air planes trains tractors ships all do it. Planes are the worse. Sitting in one of those all i can smell is raw kerosene. I say that on the plane peeps think i am crazy. Realy bad in winter
Anyway. The revenue assurance officers are getting kinda greedy
Old 07-08-2014, 09:38 PM
powrstrkr's Avatar
powrstrkr powrstrkr is offline
powrstrkr has a good reputation on FTE.powrstrkr has a good reputation on FTE.
Yeah - Saw that piece on FOX News tonight. It said the EPA said that altering engines to roll coal is illegal. Maybe in a gasser but in our vintage trucks - I don't think so!! I have a permanent pollution exemption cert from the State of NM. I just hope the publicity doesn't fire up the EPA to come up with something else to hurt our trucks. Last thing was going to ULSD. But that was an easy work around by adding a bit of 2cy oil (or other additives) when filling up.
Old 07-09-2014, 12:42 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.
Land of the free, right?
Old 07-09-2014, 01:16 PM
breedo99's Avatar
breedo99 breedo99 is offline
breedo99 is starting off with a positive reputation.
While we are on the subject, what does it take for our trucks to roll coal? Mine doesnt smoke at all whatsoever. Ive got the ts chip, 6637 filter, straight exhaust...
Old 07-09-2014, 01:33 PM
lemonshindig lemonshindig is offline
lemonshindig is starting off with a positive reputation.
Rolling coal SHOULD be illegal.
What's the point? You're pushing a bunch of unburnt or partially burnt fuel out the exhaust and causing excess pollution.
For race trucks (non-street), fine. The intent is to maximize power in a customized application. I have no problem with that; modify as much as you want to.
But if it's modified to the point of no longer meeting the emissions requirements of the year it was built, then it shouldn't be legal to drive it on the street. In fact, I don't believe it is. Just because your county doesn't require emissions testing does not mean that federal emissions standards aren't the law. There is a reason that it is illegal for shops to defeat emissions equipment on vehicles that are registered and non-exempt from emissions.
That said, I have removed catalytic converters before, and probably will in the future too. But, it IS illegal, and it should continue to be.
Old 07-09-2014, 01:52 PM
Gicknordon's Avatar
Gicknordon Gicknordon is offline
Gicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to allGicknordon is a name known to all
There was an article on aol the other day that said anybody that rolls coal hates Obama and is only doing it to protest environmentalism.
Old 07-09-2014, 02:12 PM
BBslider001's Avatar
BBslider001 BBslider001 is online now
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
Quote:
That is not even worth responding to.
Old 07-09-2014, 02:39 PM
iverger's Avatar
iverger iverger is offline
iverger is starting off with a positive reputation.
Quote:
Banks proved years ago that it doesn't add value even off the street.
That said, I still have no love for the EPA. Soon they'll be working with state governments to meter my water well and tax or ban my wood stove.
Old 07-09-2014, 03:02 PM
totalloser totalloser is offline
totalloser is starting off with a positive reputation.
Sort of a misleading issue. Lower compression DI engines properly tuned for fuel efficiency usually will smoke until the turbo catches up.
The assumption that unburnt fuel equals inefficiency is only partly right. Full load smoking is more efficient due to unburnt losses being overcome by pumping loss efficiency.
Stoopid emissions regulations have absolutely ruined efficiency in diesels, and it's no mystery. Burning more fuel is not good for the environment, and DPF junk is feel good legislation.
The real solution would have been airflow improvements, which are illegal in many states, such as twins. Twins clean it up across the spectrum for particulates, and a basic NOX cat with egr would clean up the rest.
Emissions standards are concocted by politicians, not engineers or mechanics. And it shows in the implementation of technology.
Old 07-09-2014, 03:34 PM
Gicknordon's Avatar
Quote:
Political Protest Or Just Blowing Smoke? Anti-Environmentalists Are Now 'Rolling Coal'
Read for yourself
Old 07-09-2014, 03:37 PM
They are not really concerned with efficiency. It is emmissions that the EPA is really worried about. That's why my 1996 gets about 19 mpg and a 2015 would probably get 19 mpg. Despite all the newer technology that should improve efficiency, it is offset by the equipment used to reduce emissions.
Old 07-09-2014, 08:00 PM
coreyallan01's Avatar
coreyallan01 coreyallan01 is offline
coreyallan01 is gaining momentum as a positive member of FTE.coreyallan01 is gaining momentum as a positive member of FTE.
I don't even know where to start with this but I will say we, (and when I say we I mean those who find it necessary to "roll coal"; not me) asked for this by doing so. I mean really, in this day and age did anybody think they'd get away with spewing black soot into the air in front of all the smart/E/flex/I/dual take your pick cars on the road and all the liberal fruit loops that have rendered us a minority without people talking to their senator... This sucks but its what its come to.. I can't venture to say what'll come of it, maybe tickets like loud pipes on bikes like here in Maine which they looooosly enforce... Maybe us old truck guys wont have to face the brunt of it.. I'll say my truck is plenty satisfying where its at, doesn't need a whole hell of a lot more anything...
Story just for the hell of it.... The tugboat I work on has MTU "Detroit Diesel" 16V4000s rated at 2700hp per side. They meet the "tier 3", https://www.dieselnet.com/standards/us/nonroad.php emissions the EPA and other governing bodies have agreed to as acceptable for nonroad diesels. Anyhow the ironic thing is that these are non DPF twin turbo/sequential turbo engines, they are load sensing and on my vessel @ about 1450rpm the 2nd turbo goes online and with it a CLOUD!!!! of soot/black smoke/and general mayhem happens for say 3-5 seconds till it starts turnin and clears out.... No one can see this, no prius drivers, no irate granola eaters, no NPR listeners (BTW NPR listeners, listen to the credits of who's grants funded your precious shows)... Rockefeller, Vanderbilt, Carnegie, Morgan and FORD!!!!!! These fellas after amassing all their cash Carnegie in particular decided that he'd see how much he could give away... People are so jaded... Everybody outta get their heads outta their asses remember where they came from and focus on the real issues we've got going on here.... Just sucks..... dang EPA, good politics/ bad politics is what this is alllll about....
Old 07-09-2014, 08:52 PM
powrstrkr's Avatar
The EPA just announced they have the power to garnish your wages if they THINK you broke one of their regs without going thru the courts or having to prove anything. The burden of appeal and proving innocence is on YOU while your check is being robbed. Shows you where the EPA is at!! They deserve to be snubbed. What pollution devices did a 96 PSD come from the factory with? A cat in some states? A cat on our 7.3s is nothing but an ashcan that clogs up, killing power and mileage. Working as an environmental engineer I have to follow a million regs at work, but in my own life, I'm doing what makes sense and saves money. My truck runs much better than stock, gets better mileage and will blow smoke if I want it to but I don't do it for jollies like the serious coal rollers. Almost every branch of govt is getting way too big and tyrannical and the EPA is near the top of the list. If there ever was a govt org that needs to be reined in, it's the EPA. They may be in a tie with the IRS.
Old 07-10-2014, 12:34 AM
Not saying it is not true, but that the claim is not worth responding to...I never thought Nobama was worth even reading about.
Closed Thread
The FEDS Are Coming OneCylinder 6.0L Power Stroke Diesel 15 02-10-2016 09:46 PM
EPA threatens to make converting your truck/car into a racecar illegal. 54Hydro General Automotive Discussion 1 02-10-2016 07:50 AM
EPA Requirements on our Diesel Engines wharrell 6.7L Power Stroke Diesel 44 09-26-2015 11:03 PM
No more Rolling Coal in NJ Sparky83 New Jersey Chapter 2 05-15-2015 01:50 PM
EPA Gestapo helilog56 6.0L Power Stroke Diesel 10 07-15-2014 12:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
