7.3 Bad injector - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
7.3 Bad injector
Old 07-08-2014, 06:46 PM
Smokey_7.3 Smokey_7.3 is offline
Smokey_7.3 is starting off with a positive reputation.
7.3 Bad injector
You guys are awesome! I can't thank yall enough for the help I've received here.
But onto the next challenge!!!!
My 96 7.3l has a dead cylinder. Scanner says cylinder 5. What all is required and is there a good write up on how to replace the injector myself?
Old 07-08-2014, 09:46 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
May not be the injector. Could be the wiring to that injector. Check the plug on the valve cover gasket for burnt pins.
Old 07-08-2014, 11:25 PM
Well I have a set of 8 OEM injectors and a different gasket I have laying around. Took me a little while to figure out how it all came our but it's done.
She's still puffing like a chain smoker but runs smoother.
Old 07-09-2014, 12:27 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Quote:
Originally Posted by Smokey_7.3 View Post
Well I have a set of 8 OEM injectors and a different gasket I have laying around. Took me a little while to figure out how it all came our but it's done. She's still puffing like a chain smoker but runs smoother.
Puffing what color. I'm assuming you pulled the injectors but did you replace the orings.
Old 07-09-2014, 12:43 AM
Blue.
Yes I did replace the orings on that 1 injector I replaced. I didn't swap all 8.
Old 07-09-2014, 08:49 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Blue should disappear, its probably oil left over in the cylinders from the injector being changed out.
Old 08-22-2014, 04:58 PM
Turns out it was a bent connecting rod. Replaced and smoke went away. Thanks you guy!
Need help on injectors for 7.3 7.3Powerstroke11 1999 - 2003 7.3L Power Stroke Diesel 12 12-17-2015 03:18 PM
'88 7.3 hard starting, injectors? pjcat Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 04-15-2015 03:21 AM
7.3 miss alan szynkowski 1999 - 2003 7.3L Power Stroke Diesel 1 11-26-2014 12:26 PM
7.3 AD injector solenoid ok on an AE? vegtoph 1999 - 2003 7.3L Power Stroke Diesel 5 04-26-2012 10:18 AM
1990 f-250 7.3 diesel fuel line? BCL27 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 04-12-2011 12:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
