2010 Expi EL won't start (or crank) after driving - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 07-08-2014, 04:46 PM
woodie woodie is offline
woodie is starting off with a positive reputation.
Spent about an hour searching this forum but didn't find anything directly applicable to this.
My neighbor/friend has a 2010 Expi EL, 30K miles that has developed a very strange problem. After driving for a while (30 minutes or more), stopping and shutting the Expi off, the Expi will not start again. Won't even crank. If you let the Expi sit for 30 minutes or so, it will start and run fine. Runs fine until you shut it off. When it will not start/crank, everything else electrical seems to work fine. Battery checks fine. Been in the dealership 2 times now. Several modules replaced, each time the dealership says they 'found it'.
But, no such luck. I went with my friend to pick up the Expi and listened to the explanation of what was wrong. To me, the dealership doesn't sound like they have a clue what the problem is, they couldn't answer a few questions I asked about fuel delivery. Last module replaced had to do with the transmission. My friend drove it home, about 40 minute drive and once again, it wouldn't start after it was shut off. We let it sit for an hour or so and it fired right up.
Needless to say, my friend is not a happy camper. I suggested he go to a different dealer which he is considering. I thought I would pose the problem here for any input of what this could be. Since it seems to be 'running time' dependent, I suspect a heat issue. It takes a while for the fault to occur, and after sitting when the problem occurs, it disappears. Heat related? Strange thing is, you can drive it and everything is fine as long as you don't shut it off. Then you have to wait for about half hour to resolve the issue.
Any ideas?
Thanks
Woodie
Old 07-08-2014, 05:59 PM
carguy94 carguy94 is offline
carguy94 is starting off with a positive reputation.
check for power down at the starter motor see if it is getting power. when their is a heat issue you have expansion something that is normally cold heats up and can cause bad or no connection fairly common when a starter motor is failing internally. beings this is a no crank no start this is about the simplest place to start since it only happens when its hot this will give you direction as to were to look and what to test.
Old 07-12-2014, 02:02 PM
Thanks carguy
I passed the suggestion along to my friend and I think he asked the dealership if they had checked the starter. Will post here with any results.
Woodie
Old 07-12-2014, 04:11 PM
landlubber landlubber is offline
landlubber is starting off with a positive reputation.
Using the "SWAG" system. What pops into my mind is the starter solenoid. But that would be one of the first things to look at. Seen that before on older vehicles, where the solenoid would not work when hot.
Old 07-24-2014, 12:22 PM
Quick update
The dealership finally figured it out. The wiring harness and module from the transmission was faulty when hot. Basically, the module or wiring were not indicating the truck was in 'Park' and would not engage the starter. Why it took this long to find it is very strange, but the truck is working correctly now.
Woodie
Update.... Because it too so long for the dealer to figure this out, and my friend was taking a family vacation and had to tow his Airstream trailer, he purchased a new Suburban. So, he had to sell the Expi when he finally got it back from the dealer. Guess who the new owner is.... Yep, me Have driven it for several days with no issues, it is still under an extended warranty, etc. Beautiful truck, love the way it rides and is much quieter than my '05. My son wants my '05 (he also took my original '97 which still runs fine after almost 200K miles) and thought he needed an upgrade. As he put it, he knows the history of the truck and it has had a pampered life in my garage.
'83 f250 will not start after getting warm 1983f250guy 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 04-11-2016 08:24 PM
Strange random no start. TheBlueMule 6.0L Power Stroke Diesel 7 04-02-2016 08:31 AM
2000 Explorer 4.0 V6 fuel supply problem? woodie Explorer, Sport Trac, Mountaineer & Aviator 11 06-30-2015 06:19 PM
2010 Expi EL Limited transmission/cruise issues woodie 2007 - 2014 Expedition & Navigator 18 10-21-2014 10:49 AM
Seat A/C problem indy358 2007 - 2014 Expedition & Navigator 7 08-28-2014 10:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
