911! Parts fell out of brake drum and brake dust everywhere!
I was rotating the tires on my sig truck and on the right rear I pulled the drum cover off. I found a LOT of brake dust covering everything and these two parts fell out. What are these to? Is it safe to drive to a shop to be serviced?
I also found this in the bottom of the brake drum
Part of the self adjuster, you can see it here.
Part you have in your hand here (cable missing or hanging in place yet.
other end cable in place
Not sure about your last picture, If liquid looks like water rather than grease, you got little water in it taking it off or right afterwards?
Not 100% clear what you're asking about there.
The second picture looks to me like its greasy (I'm thinking break fluid) and brake dust. I basically just want to know what is going to cost me to fix this and what parts I need to order for it. The piece on the left side of my hand has a jagged edge like its been snapped.
And thank you both very much for the help so far. Definitely has eased my mind. Any help or links to necessary arts are appreciated
Might be brake fluid, run your finger through that wet spot then smell your finger, smell like brake fluid?
Hard to say cost wise you didn't show us everything.
Best bet replace shoes replace hardware kit including self adjusters/cables (cables are not included with hardware kit nor self adjuster).
If wheel cylinder is blown or questionable replace it, might be leaking due to shoes/drum both at or beyond wear limit. If so odds will leak with new shoes/drums drums turned are low. Wheel cylinders are cheap just replace it if any doubts.
Have drums measured, if within spec can be turned have them turned.
Any signs of axle grease in there pull the hub replace its seal.
Keep in mind system like that, rear axle with large drum and large shoes, fix it now fix it right and you won't be in there again for a very long time.
Turn your drums, Shoes Complete hardware kit with cables springs and adjusters and adjuster plugs.
You DO NOT want to reuse that spring. Hardware kits are cheap. Drum turns are cheap and shoes aren't to bad. I would replace the wheel cylinders and soft lines as well. If your in there gett'er done and be done for along time.
This is a F350, right? Full-floating rear axle, right? Thus, the need to pull the axle to access the shoes, right?
If so, all the more reason to replace everything in there (including wheel cylinder) and the grease seal.
Roy
Heres a clear view of the brakes, aid in making double sure putting things where they go no hub in the way.
(left side pictured, right side would be mirror opposite)
Roy
Tye,
Regarding the hub seal (if it needs to be replaced):
After you get Red Baron's axle out as danr1 has described you'll need to get a hub wrench for your full floating axle (Dana 80), a puller (two or three jaws), and a step plate adaptor (Ford Tool D80L-630-7) to get to the oil seal and outer wheel bearing. Remember that the hub nuts are either RH or LH depending on what side of the vehicle you're working on.....also double check the axle shaft's o-ring seal (while you're in there it's a good idea to replace it as well).....
