New to me 2000 7.3, already a problem.
Old 07-08-2014, 08:16 AM
blackgold50's Avatar
blackgold50
blackgold50 is offline
Hey guys, I was hoping my first post here wasn't an issue but I just picked up a 2000 F250 7.3 xcab with 210k miles on it. Looks like a lot of maintenance has been done and it ran good when I picked it up and drove it 200 miles home. Anyways, last night I drove it to go help out a friend, mid gentle accel, RPMs dropped to 0 for a second then picked up and drove fine... about 30 seconds later it did it again, then another time worse and the SES light came on. I backed off the pedal and drove it slowly for a few minutes. I stopped at a light about 5 seconds after the light, it stalled and engine died. I coasted off the road and turned the key off, then started it no problem. The SES light was off and I drove it 5 minutes home. About 2 minutes from my house, the SES light came on but there was no hiccup or loss in power. Once I got home, I shut it down then restarted with no light.
I don't think any of this matters much but 20 miles before this happened, I topped the truck off with 10 gallons of Diesel from Sam's Club and added some diesel clean cetane boost (it was a bottle that treated a 100 gallons and I realized I probably added a little more than a 1/4 of the bottle). I also sprayed some corrosion detector/neutralizer on the battery terminals and replaced the wiper blades.
After a little searching last night, the symptoms seem similar to the TPS. I went ahead and ordered one because it was cheap. I also bought motorcraft 15-40 oil a motorcraft oil filter along with a wix fuel filter that I plan on doing tomorrow along with the TPS possibly.
Anyways, am I on the right track with this?
Thanks in advance for the input.
-bg
Old 07-08-2014, 08:23 AM
snakedoc's Avatar
snakedoc
snakedoc is offline
It could be a cps or uvch. Need the codes to know
Old 07-08-2014, 08:26 AM
blackgold50
UVCH? is that the glow plug harness? THE PO said that had been done in the last year. Will Autozone scanner pick up the codes? Thanks,
Old 07-08-2014, 10:05 AM
Christof13T's Avatar
Christof13T
Christof13T is offline
The parts store scanners are hit and miss.
Cheaper to buy a cps and swap it than to take it to a dealer to get it scanned.
Odds are with what you describe its just a cps.
Uvch = under valve cover harness.
It handles the glow plugs and injectors.
Old 07-08-2014, 11:07 AM
blackgold50
Ok... I'm picking up a CPS today.. it's only 30 at the dealership.. I'll work that in with my work tomorrow on it. Hoping to have it resolved for it's first towing job this weekend. I bought it to tow my toy hauler my wife and I just bought.
Thanks for the replies. Really looks like an awesome inFORUMative forum.
-bg
Old 07-08-2014, 02:14 PM
Christof13T
We do our damndest to save forum members money in getting their trucks back up to 100% healthy...
Where we really shine is helping folks decide how to spend their hard earned dollars on performance modifications.
Window shopping is so much more fun when its someone else's dime lol.
Old 07-08-2014, 02:45 PM
blackgold50
haha, thanks... Well, I picked up the CPS today, TPS will be here tomorrow. I plan on installing both for safe measure and disconnecting the ifv or whatever is next to TPS to spray some electrical contact cleaner in it to clean it a bit. Any other cheap things that are good to replace while I'm at it?
Thanks,
bg
Old 07-08-2014, 04:26 PM
DND58's Avatar
DND58
DND58 is offline
Here's some good reading. While all may not be cheap, These are good things for longevity. And welcome aboard!
https://www.ford-trucks.com/forums/1...on-thread.html
Old 07-08-2014, 06:42 PM
snknby123's Avatar
snknby123
snknby123 is offline
Yes, welcome to the club. We are here to help and spend your money.
Old 07-09-2014, 09:33 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
Thanks,
bg
Why not just try the CPS first...if you replace both at once and it fixes the problem, you will have no idea what the original problem was?
Old 07-09-2014, 12:34 PM
blackgold50
The cps seems to have fixed my problems. I still wanted to replace the other today when I get off. I added a bit if marvels mystery oil to the oil this morning to clean a bit before change it today. Do any of you add it to your oil changes from the start? Saw someone say sub 2 quarts of oil with mmo. That seems high. Was thinking maybe just half a quart? Thanks,
Bg
Old 07-09-2014, 12:48 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
I wouldn't add anything to the crankcase but the correct grade of engine oil, honestly.
Old 07-09-2014, 01:34 PM
petrokiller's Avatar
petrokiller
petrokiller is offline
NO OIL ADDITIVES! Leave additives for Fuel only.
Think of the CPS as a pace maker in a bad heart.
It's like timing in an old engine.
Run it hard going to work if it doesn't miss a beat, hook up the camper and go.
Throw the other parts in glove box for later.
Old 07-09-2014, 03:08 PM
Pikachu's Avatar
Pikachu
Pikachu is offline
Another thought on the Marvel Mystery Oil: when it's added to diesel fuel, it actually lowers the lubricity of the fuel. If it does that to fuel, I can't imagine it would actually make engine oil any better.
Old 07-09-2014, 04:25 PM
bdpotts's Avatar
bdpotts
bdpotts is offline
i was thinking CPS and uvch as well. glad to hear the sensor fixed it. welcome to the site, you'll be amazed with the discussions that take place!
cheers from oaktown'!
Quick Reply: New to me 2000 7.3, already a problem.
