Lokar throttle cable setup - Ford Truck Enthusiasts Forums
Old 07-08-2014, 09:10 AM
tjdad62's Avatar
tjdad62 tjdad62 is offline
tjdad62 is gaining momentum as a positive member of FTE.
Hey all,
For those of you using Lokar throttle cables, can I see pics of how your setup turned out? I want to use them on my 50 F3 with a 302 and AOD.
Thanks in advance,
Randy
As a side note, has anyone used a throttle pedal assembly out of a mid 70's pickup? The kind that bolts to the firewall.
Old 07-08-2014, 09:34 AM
56panelford's Avatar
56panelford 56panelford is offline
Posting Legend
56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation56panelford has a superb reputation
I don't have any pics but I have thier through the floor pedal and hooked up to a Holley Stealth ram injection system and it was quite easy to install. I had to get longer srews to mount the pedal because of the thickness of the carpet. Be sure to get the proper snips for cutting the cable or you will have a mess.
Old 07-08-2014, 09:53 AM
tjdad62's Avatar
Thanks 56panelford,
I am going to try and use the original gas pedal and lever system if at all possible and adapt the cabling to complete it. Not sure that will be feasible but will give it the old college try...
Old 07-08-2014, 03:13 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Here are a couple of pics I found of my Lokar hook up. One is of the underside of the aftermarket gas pedal, and the other is of where the Lokar gas and C4 kickdown cables hook up to the carb on my 302. (Dirty dirty motor at the time, shame) "EDIT" I should have mentioned , the main reason I went to an aftermarket pedal, was so I could relocate it a little further away from the brake pedal. I used to hit the gas sometimes when I hit the brake, if I was wearing work boots. So I never tried to fit it to the stock pedal.
Old 07-08-2014, 06:10 PM
ChuckRob's Avatar
ChuckRob ChuckRob is offline
ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.ChuckRob has a great reputation on FTE.
Used the throttle pedal and AOD kickdown cable. So far I like the setup, be sure that you order the spacer to go under the pedal because of carpet thickness.
Lokar - Foot Brake- What about cables? Don Vito 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 11-16-2016 10:41 PM
Kickdown cable? schoo Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 04-02-2016 10:59 AM
Problems with Lokar throttle cable assembly? perks56 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-17-2013 09:11 AM
Lokar 48" cable & Offy C F-250 restorer Ford Inline Six, 200, 250, 4.9L / 300 2 02-11-2013 07:37 PM
Lokar cable for C6 kickdown? F-250 restorer 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-12-2013 02:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
