P.B. squeak
07-05-2014, 06:32 AM
on
P.B. squeak
i was out driving this week and i have develop a squeak when pushing the pedal , i have tried to lube things on what i see , i think it might be on the inside ? i never took a booster off the master cylinder before ,, i just dont know, its not the pedal pivot,,its kinda like a air sound too ,, i have great breaks ( power ) ,, do i need to take the booster off the cylinder ??
thanks
07-06-2014, 12:08 PM
You need to put in a good sound system with a lot of volume!
07-06-2014, 12:12 PM
on
i am going to contact the people i bought it from , got to be something going on , kinda like air breaks lol
thanks
07-07-2014, 05:34 PM
on
i called them to day and they want me to check the check value ,, it was fine , no leaks , i did the test on it and while it was not running it made the sound until it pumped up and it stopped , after i started it up and it sucked more air it started to make the sound again ,, so i guess i call them again
07-07-2014, 08:16 PM
It sounds like the booster has a vacuum leak.
07-08-2014, 05:47 PM
on
i have check the check value , and it holds ,, if i take the master loose and side it out will i see anything ? or is there anything else to check,or do i need to just replace it
thanks
07-08-2014, 06:00 PM
Check valve is cheap and easy to change. Check rubber seal it plugs into and vacuum hose for cracks. I've never seen a booster itself develop a crack or leak unless over tightened when installed. Do you have a dual diaphragm booster? If so maybe one diaphragm is ruptured?
07-08-2014, 06:05 PM
on
thanks ax
i have looked at that also it seems to fit fine ,, real snug ,,i think you mya be right about the dual diaphragm booster,, if one is bad would i still have good breaks ?? make sense for sure
thanks guys
1986stepsidef150
07-22-2012 09:45 PM
spongecop
02-13-2011 04:10 PM
cornfedp
12-05-2008 06:18 AM
PCWest13
05-09-2005 02:13 AM
science_rules
1978 - 1996 Big Bronco
02-27-2003 09:23 AM
