Australia Chapter Join Chapter , Leader: ChunderDownUnder
P0284
Old 07-16-2014, 02:37 AM
Diesel Submariner's Avatar
Diesel Submariner
Diesel Submariner is offline
P0284
G'day Fellas,
Ran a few tests on the Henry today (AE from Clay).
Dead cold and did the KOEO and all good (Buzz test, sensors etc).
Checked for codes and only had P1211 and that would be the PHP FU2 6 Pos Chip. Also the soft code that throws due to AIH Delete mod (can't think of the number off top of head P03--).
Cleared the codes and P1211 didn't reappear for the rest of the tests.
I left the Chip in during tests but had it set at the lowest (Extra 25HP being closest to stock).
Took her for a good run to get up to full operating temps and ran a KOER test and all good.
All data looked good ICP, pulse widths etc.
Ran a Cylinder Contribution Test and came up with:
P0284 Cylinder 8 injector circuit contribution/Balance fault
The truck is running beautifully with no sign of a miss, smoke etc.
I know that the Gray CPS can throw this as a Phantom Code.
Just wondering if any of you fellas get the same code on our Aussie 7.3 trucks?
Cheers,
Reg
Old 07-18-2014, 05:39 AM
SSSimon's Avatar
SSSimon
SSSimon is offline
Reg, I'll check my DTC log and let you know.
I'd be inclined to clear the codes, use the truck normally, and check for a re-appearance before you worry too much about it.
Old 07-25-2014, 03:35 AM
Diesel Submariner
P0284
G'day Simon,
Done that mate as a matter of course.
However it comes up again after retesting.
Still let me know if and when you throw the AE over yours again.
Cheers,
Reg
Old 07-25-2014, 10:06 AM
BigF350's Avatar
BigF350
BigF350 is offline
Old 07-26-2014, 08:06 PM
ChunderDownUnder's Avatar
ChunderDownUnder
ChunderDownUnder is offline
agreed. dont worry about #8. it has a different stroke than the others. Fords lame *** way of trying to fix the fuel starvation on that cylinder. The only real fix is to install a regulated return.
Old 08-07-2014, 04:47 PM
Blue7.3's Avatar
Blue7.3
Blue7.3 is offline
I fitted Clay's FRx and that seem to settle the noisy number 8 down some and also fitted the HPx as well , some say this will give you a smoother idle but that's debatable.
I run AE last week and pulled some codes
B1428
B1483
B1352
which are no weal problem as for the AIH delete , i still get a soft code but no biggie , i made up a wire with some resistors in line to stop the soft code , will check it out and let you know.
Gatordog
05-21-2016 07:13 PM
bcaughhorn
44
12-12-2015 10:30 AM
cassenbl
07-30-2012 11:11 AM
ballbandit
02-05-2012 09:46 AM
foxracing0934
10-22-2008 01:11 AM
Quick Reply: P0284
