Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 07-08-2014, 02:52 AM
MiamiPSD's Avatar
MiamiPSD MiamiPSD is offline
MiamiPSD is starting off with a positive reputation.
Garrett Turbo Rebuild
At what milage interval does the garrett turbo need rebuilding. I will be pulling the turbo soon for o rings and a few other goodies and wanted to see if I should rebuild my turbo. I have 72K on my 2003 - 7.3l
__________________
George "Nothing but the U" Go Canes.
03 F-250 CC 7.3L PSD Lariat 4X2, John Woods VP, Precision Stallion 3-Disc converter, Dieselsite Cpr+, 203*w/billet housing and coolant filter, DP (F5) Tuner, Banks exhaust, AIS, RR billet wheel, Isspro Performax gauges, 6.0 cooler w/ Cat 1 ELC, HPX, Hutch & Harpoon, Alum. Diff. cover, Bilsteins, Mobile1, 18" XD RockStars, Michelin's MS/2 LT275-65-18, AE-Ford Bundle
Old 07-08-2014, 02:57 AM
SpringerPop's Avatar
SpringerPop SpringerPop is online now
Too old to be too smart..
SpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputationSpringerPop has a superb reputation
A lot depends on how clean you keep your oil.
I currently have 225,000 on the original turbo, and it has no sign of having problems.
Pop
__________________
-Marv- a member of The Brotherhood
"Some of us pride ourselves on the money we've spent on our trucks, and some of us on what we have NOT"
2000 F350 Lariat 7.3,A/T,CC,LB,4X4,SRW, CCV, Sonnax/springs, Dahl, spin-on trans filter, spin-on hydraulic filter, coolant filter, 6637 & cover, bypass lube oil filter, HPX, Hutch n' harpoon.
Email SpringerPop SpringerPop's F-350
Old 07-08-2014, 02:59 AM
MiamiPSD's Avatar
Oil and filter every 4500 miles.....
__________________
Old 07-08-2014, 07:27 AM
Dan V Dan V is online now
Dan V has a good reputation on FTE.Dan V has a good reputation on FTE.Dan V has a good reputation on FTE.
Quote:
and only 72k.....you're good for a spell!
__________________
'01 F250 4x4 Crew Shorty, PM Rods, new PIS 160/30's, D66 compressor by Dieselsite/w 1.00 ex housing, EBPV delete, ITP Regulated fuel return, S&B CAI (dry filter).
Old 07-08-2014, 08:56 PM
KJNDIVER's Avatar
KJNDIVER KJNDIVER is offline
KJNDIVER has a good reputation on FTE.KJNDIVER has a good reputation on FTE.
Ive got 296k on my original turbo. Although i plan on doing a rebuild probably this weekend, not because of need, but i want to upgrade to the ww2, and if im gonna go thru the trouble of taking the turbo out of the truck, i may as well do an overhaul of the thing with close to 300k on the clock. it could go on for some time more, but i dont wanna press my luck. no whammy, no whammy, no whammy, STOP!..... I only wanna do it once.
__________________
Damon
2001 F250 7.3 CC 4X4, 300k+; ISSPRO EV2 EGT TRANS BOOST, 6637,HPx, FRx, 50˘ , 5" exhaust, BTS TRANS W/ 6.0 COOLER, DP F5, WW2, TM Wastegate, AIH Delete, Bypass Oil & Coolant Filtration;harpoon, Hutch mod, 6.0 mirrors. Coming Someday: Melling LPOP, FluidAmpr, R4 Tech, rear camera
Old 07-08-2014, 09:44 PM
snknby123's Avatar
snknby123 snknby123 is offline
snknby123 is gaining momentum as a positive member of FTE.snknby123 is gaining momentum as a positive member of FTE.
What orings are you pulling it for exactly? Just curious but like everyone has said, that's low miles for 7.3L and the Turbo. You should be good to go for another 100K as long as you keep the oil and air clean.
__________________
2001 F250 Lariat 7.3L ISSPro Gauges, Van Turbo 1.15AR with WW2, IAH delete, EBPV Delete with Blank Pedestal, IH Bellow pipes, Rebuilt 4R100 with Transgo HD kit, 4" Turbo Back MagnaFlow, Ford AIS, Hutch and Harpoon, RiffRaff FPx, RiffRaff CVD, FTE Resonator, Hydra with Gearhead tunes.
Old 07-09-2014, 01:24 AM
MiamiPSD's Avatar
My pedestal o rings are leaking so since I thought on doing the pedestal non epv and outlet and take care of the o rings then.
__________________
Similar Threads
Garrett m43 turbo rebuild kit?? hardwaterfreak Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-21-2011 10:37 PM
ATS turbo part number? bigblockford_390 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 03-06-2010 11:05 AM
Where to find a turbo rebuilder? JesterPgh Pennsylvania Chapter 3 04-13-2009 07:27 AM
Turbo Model? BOBSDIESEL 1994.5 - 1997 7.3L Power Stroke Diesel 5 02-28-2009 01:21 PM
Turbo Rebuild Sharpshooter77 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-27-2008 10:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
