any interest in a 254 Big Six Flathead ? - Ford Truck Enthusiasts Forums
Old 07-07-2014, 11:34 PM
jmadsen's Avatar
jmadsen jmadsen is offline
jmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to alljmadsen is a name known to all
Ok. So ive had this engine sitting under the carport for over a year now with intentions of doing something with it. It came in a 1951 f6 truck, it had been rebuilt at some point in time. (Bores are .040 over) the farmer was hauling grain when the valve broke off at the stem and punched a hole in the top of the #1 piston. There is a slight score in the cylinder wall but could probably be honed and find a new or used piston and rings and put it back together for a runner or complete teardown and bore to 50 or 60 over or sleave #1 and keep it all 40 over. ????
The po had pulled the pan to remove the rod and piston. And all i have done is pull the head. Its a complete engine carb (i think ive got the oil bath air cleaner) to pan, fan to flywheel.
Im thinking of doing the classifieds section or maybe ebay.? If nobody here is interested?
Im not selling anything on this forum, even if it sounds like i am. only feeling out if anyone here is even interested in a hard to come by engine before going to other means to move it along.
Feel free to pm me or send an email if anyone is interested or has questions
Old 07-08-2014, 07:21 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
First, I am personally not interested but only because I already have a rebuildable M six cylinder taking up space. I think this is a great engine for anyone with a flathead six in their truck (or car). Someone should take you up on this.
Old 07-08-2014, 10:02 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
Geez, Josh, Do I need to send more for the 254? Would like one for my F6.
Old 07-09-2014, 10:25 AM
jmadsen's Avatar
check out this T Roadster with a 254 six in it! found on the Hamb
Old 07-09-2014, 11:32 AM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
Quote:
All you gotta do is push it across the hall when no one's looking...
Old 07-10-2014, 07:42 PM
nsboyd1210 nsboyd1210 is offline
nsboyd1210 is starting off with a positive reputation.
I believe the 226 and 254 are identical with the exception of bore. If so, the 254 would be a nice upgrade for those out there with the 226.
Nelson
Old 07-10-2014, 09:58 PM
havi's Avatar
Quote:
Sounds like a plan! lol
Old 08-23-2014, 06:37 AM
230thdratsab 230thdratsab is offline
230thdratsab is starting off with a positive reputation.
I think we've talked about this before, but I'm still interested in your 254. Thanks.
Old 08-25-2014, 06:52 AM
jmadsen's Avatar
Quote:
Sorry, its long gone, I rolled it across the hall.
Old 08-25-2014, 06:57 AM
Thanks none the less. Be well.
Having some real bad luck here psu927 6.0L Power Stroke Diesel 5 11-20-2015 09:10 AM
Blackwater Engines - .040" Over Pistons, Blow-By and Lies? creator 6.0L Power Stroke Diesel 36 08-06-2013 05:16 PM
7.3 Cracked piston, where to get a replacement. cowboybootlegger Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 12-05-2011 06:18 PM
6.0L self destruction! adamtheman16 6.0L Power Stroke Diesel 9 08-06-2010 06:14 PM
What I found in oil pan BigBrownTruck FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 03-15-2001 12:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
