91 F250 Fuel Pump
will the truck start. pull codes from the engine. if your fuel pump will not shut off unless their is a wiring short or something in between the EEC then that could be bad causing the pump to run all the time. do you know were the diagnostic test port is on your truck and the one in the cab.
Echelon
12-06-2014 06:55 PM
deanna197
05-28-2011 08:21 AM
Ohio Farmer
10-26-2004 11:35 AM
