Rear wheel blocks, however RABS should prevent it. Why? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 07-07-2014, 03:16 PM
E150 4.9 1990 E150 4.9 1990 is offline
E150 4.9 1990 is starting off with a positive reputation.
It's a 96 E250. ABS light is not on. After ignition 2 sec. and light goes out. So the unit thinks it is everything alright. But it's not. When Braking hard, rear wheels block and I have to keep the van straigth not to come off the road...Sometimes funny, sometimes it's not.
How irt began: Rear drum was warped. Corrected by a machine shop, new pads and cylinder mounted. I thought it's ok. It was good for a while. Then it started to seize. I got off the brake but the van doesn't start to roll. Only if I pushed the throttle. Ok I check the rear axle, it is hot. Fine. Drum controlled it is warped again. Fine. Cold no seizing. Logical. The diameter differences became too big at different points of the drum and the self adjuster adjusted himself to the biggest diameter of course. So at the smaller diameter areas the pads rubbed the drum = overheating again. But where comes the diameter difference? I think the rear brake works with too big performance. The front brakes should do 70% of the braking job. If so the rear drum never overheats. We rebuilt then the front brake because we thougth there can be some mechanical problem with it ( there was, the pistons where disgusting ). When I brake hard the rear blocks still. Tomorrow I will check the front and the rear brake performance so we will know how they perform. Maybe the result will be good and the rear drums won't be overloaded in future and no warping will come but the blocking wheels still make me nervous.
There is the damn ABS and it blocks. No codes. No ABS light on. What's going on there?
Old 07-08-2014, 06:14 PM
jimandnena jimandnena is offline
jimandnena is gaining momentum as a positive member of FTE.
Hi,
My '88 E150 doesn't have ABS but my '92 F150 did, might be similar.
I sounds like pressure in the rear brake lines might be holding pressure on the rear drum? If I remember correctly (always a danger), there is a proportioning valve on the master cylinder. It may only be on the pickups? I replaced the master and got that valve in wrong and it locked the rear drums. If that valve is malfunctioning, it could hold pressure.
Sorry I don't know more about it, just that small bit of experience.
jim
Old 07-12-2014, 01:18 AM
OSHS OSHS is offline
OSHS is starting off with a positive reputation.
I don't know about the earlier vans, but on my 2001 15-passenger, even with the V-10 up front, the rear is significantly heavier than the rear. I have never weighed it (each axle, that is), but the effort to raise it via a floor jack is 2x for rear.
As for your van with rear drums, there is a valve, either part of the MC or in the rear lines that is designed to keep a little pressure on the shoes. This is a feature of rear drums. I'm too young to remember where it is located.
If you jack up the rear axle and cannot turn either wheel, you have a problem. That valve is suspect, especially if you cannot freely turn both wheels. Before you go hunting for that valve, make sure the emergency brake is adjusted properly. Beyond that, a flexible brake line could be collapsed (read: old) and causing drag. Drag causes heat, heat causes warping.
On the plus side, I just did a friend's rear brakes on a 2005 Buick Park Ave. She had worn the rotors paper-thin and required new calipers. The pistons were over extended and sitting cockeyed. Oh, and she showed up to the house with the brake light on (dash light, meaning low fluid). The rotors were literally paper-thin. Never seen anything like it before. At least not in person. New calipers, new rotors, new pads.
Old 07-12-2014, 05:26 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Quote:
Not trying to sound too sexist or disrespectful to the other gender but they can and do occasionally run a vehicle long past time to have it repaired or even inspected. In fact I've heard a few more colorful mechanics cite "wimmen---could screw up a junk yard with a Q-Tip.................." I can't disagree, having once owned a body shop.
It would seem some believe the warning lights are merely suggestions, not necessarily all that important. Of course some men are just as guilty of the same thing.
Brake Dist block orientation / power drum expectations markeyd 1961 - 1966 F-100 & Larger F-Series Trucks 14 06-02-2016 07:53 PM
96 F350 Dually Brake issues Chaosracing 1987 - 1996 F150 & Larger F-Series Trucks 0 04-15-2016 04:12 PM
New drum brakes locking up LostAngel 1987 - 1996 F150 & Larger F-Series Trucks 5 03-15-2016 08:32 PM
Van shakes when slowing down redpumas18 1968-2013 Full Size Vans 4 06-23-2014 08:18 AM
broke brakes..HELP!!!!!!!!! ...ASAP!!! bronco99 1978 - 1996 Big Bronco 2 08-14-2001 08:49 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
