A question on "what's underneath the EGR" - Ford Truck Enthusiasts Forums
Old 07-07-2014, 02:18 PM
guitar_199's Avatar
guitar_199 guitar_199 is offline
guitar_199 is starting off with a positive reputation.
Hello folks. Mine is a 2007 Ford F150 4.6L V8 and for certain, my engine has the one piece EGR System Module.
Additional piece of information: I have a subscription to Alldatadiy.com for this truck.
What I am wondering is this: once I remove the EGR system module, I know that it bolts onto what alldatadiy info calls the "Throttle Body Adapter". I am taking from that that the egr port that typically needs cleaning out is right under the EGR System Module.
I suspect that I will have to remove that from the engine to do an adequate job of cleaning but, when I look up "Throttle Body" and find the removal... alldatadiy only shows removing the front part of the throttle body from the part that the EGR valve bolts to. It does not show removing that part.
When I go look at intake manifold removal, it shows pictures of the intake manifold with the whole piece already gone and the port that it bolts down to has nothing on it.
My question, DOES the piece that the EGR system module bolts on to.... come off the top of the intake manifold? Logic tells me it does but I can not find anything in alldata that deals with that one little piece and as I said, I am imagining that I will have to take that piece off to clean it thoroughly and safely.
Can anybody give me confirmation of what I will need to do once I get the EGR module off ?
I would sure appreciate it...
Bob
EGR Disconnect Instructions SpartanDieselTech 6.0L Power Stroke Diesel 972 06-21-2016 02:44 AM
Vacuum line FAQ f100beatertruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-29-2013 08:41 PM
Getting brave CR3999 6.0L Power Stroke Diesel 3 08-02-2012 09:27 PM
My experience removing and cleaning the throttle body and intake adapter on a 5.4 2V vze2sgxa 1997-2006 Expedition & Navigator 5 03-02-2011 09:30 AM
EGR Jamming / Cleaning / Deposits / No Power / gearloose1 6.0L Power Stroke Diesel 2 01-02-2011 10:18 AM
Tags
egr system module, p0401, throttle body
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
