2008 EXped radiator drain location? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 07-07-2014, 02:04 PM
mprsox mprsox is offline
mprsox is starting off with a positive reputation.
Smile 2008 EXped radiator drain location?
have an 08 exped. EL with 5.4 l engine. I cannot find the rad drain plug - is it the round red one on the inside passenger wheel well?
I thought they were hex white plastic?
trying to flush radiator fluids. I do not want to drain the block.
any help on the location and look of the drain plug?
thanks,
mpr
Old 07-07-2014, 05:45 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
Quote:
That's where all the "yucky" (tm) coolant hides.
Old 10-18-2014, 08:30 AM
Novarules88 Novarules88 is offline
Novarules88 is starting off with a positive reputation.
I've got the same question. I've looked high and low and can't figure this one out. If you have a picture that's even better!!
Old 10-25-2014, 02:24 PM
gwcloud gwcloud is offline
gwcloud is starting off with a positive reputation.
I saw this post and am thinking the original poster has long since moved on to solve his problem. I have a 2007 Navigator that probably has the same radiator. I would like to know where my drain is also. So I looked in my factory service manual and it does not show a drain plug (sometimes little things like that are not shown in the drawings). Then I looked under the hood and also under the truck. I saw a red cap on the passenger side radiator tank. I've never seen a drain capped like this so I googled the question for a radiator drain location.
Here is what I found:
Look in the engine compartment. There is a red **** (cap) near the lower right tank face of the radiator behind a wiring loom (passenger side). Turn left to open the amount you wish to drain the radiator. Tighten by turning right to stop flow of coolant. Space is tight to get to the red ****.
Richard
Engine coolant drain plug I6 '86 Ford f150 Wildpat01 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 02-21-2016 08:31 PM
Radiator drain plug leaking ? NICKSAN 1968-2013 Full Size Vans 9 11-19-2015 09:25 AM
Were is the radiator drain plug XBAJBUSX 1994.5 - 1997 7.3L Power Stroke Diesel 2 03-10-2010 12:34 PM
Engine block drain plugs hood 3.0L V6 1 09-11-2004 08:21 PM
Drain Plug on Block dallas01 Modular V10 (6.8l) 3 03-31-2003 08:06 PM
Tags
radiator
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
