91 crewcab with SD running gear. Frame off resto build.
Old 07-23-2014, 10:58 AM
damarble's Avatar
damarble
damarble is offline
Dang it I was really hoping you'd follow through with the Hummer wheels. I want to run 05+ axles but also MTRs and I still don't know if it can be done for sure.
  #32
Old 07-23-2014, 11:03 AM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
i can tell you for sure from a bunch of threads I have seen, 16.5" wheels will only clear if you run a minimum of 3.5" back spacing.
the 17s I got are tight around the front calipers, cant fit a finger in there.
9" wide 0 offset.
and recentered to an 8x170 of course.
No real way around this unless oyu get custom spacers from arrowcraft and thats 720 for 4 of em. The 8x170 really screws it up for running military wheels on the cheap.
with new wheels and tires, black rock 997s, cooper s/t maxx 37s, taxes mounted installed etc total package im at 1700. Its alot but 17s are more common and can run any tire I wish pretty much. The wheels are i think 16-17 pounds lighter a piece than the 24 bolt h1 wheels too. the h1s do look bad *** though.
  #33
Old 07-23-2014, 11:42 AM
damarble's Avatar
damarble
damarble is offline
I've heard about the 3.5" rule but nothing concrete. I don't even care about the Hummer wheels, it's the tires I want. Plain steelies work for me since I won't be airing down. If I can get some aftermarket steelies in 8x170 with enough backspacing and a high load rating I'll be set.
  #34
Old 07-23-2014, 09:50 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
You know about the Rockstars cracking, right?
  #35
Old 07-23-2014, 09:55 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
no one is running rock star wheels?
  #36
Old 07-24-2014, 04:47 AM
Diesel_Brad
On an OBS? I hope not, they are Ugly as FAUK
  #37
Old 07-24-2014, 06:32 AM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
i meant, i dunno where you got the comment of Rockstar wheels from. the wheels I got are made by black rock/cragar. -dunno
  #38
Old 07-24-2014, 07:36 PM
Diesel_Brad
I must have mis read
  #39
Old 08-04-2014, 03:33 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
dont update much ver here, my main thread is ove ron oil burners.
heres some pics that came in or are coming in.
$30 bucks for htis, picked up a 2500# wireless remote winch to replace the hand crank.
painted. buiulding the rear parking brakes up tonight
should be in next week.
C code springs
06 172" WB frame from texas, got my first coat of paint on it. Came with a class 5 hitch on it already. No fuel tank as of yet, want to get a roller on tires first to see what im dealing with. these new frames have a big cross memebr on the rear.
tires should be here in a couple days. Got some 2" long spline drive lug nuts so people dont punk my wheels.
ordered a set of header flanges from justin at R&D to start mocking up my customheaders and uppipes for the turbo, and a bunch of V band clamps.
going to grab a 6.0 intercooler soon, waiting on a set of factory 4" lift blocks for the rear, Should be a full roller by end of next week.
  #40
Old 08-04-2014, 04:11 PM
emspjay's Avatar
emspjay
emspjay is offline
Looking good!! Great thread!!
  #41
Old 08-04-2014, 04:16 PM
GuitarJesus's Avatar
GuitarJesus
GuitarJesus is offline
C code springs
Dude this is killer. How much fab work are you going to have to do to get the cab to bolt up and sit right? Is the frame the same width? I thought SD frames were wider.
  #42
Old 08-04-2014, 09:22 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
frame is 37" wide. pretty sure obs frames are the same.
I dunno i figured moving or making a couple cab mounts is the easy part vs fabbing trac bar mounts, sway bar mounts, drilling liek 50 new holes, lining up the radius arms etc.
one thing i dont know how to do yet is adapting my steering column to the new 05 steering shaft, and how to use the SD PS pump for the hydroboost. OR get an old F-superduty PS pump but then i need metric to std fittings. everything else should just drop right on. Im making my own front end and rad support so im not worried about things lining up. Im not going for a factory look
  #43
Old 08-06-2014, 11:38 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
Tomorrow paintning underside of front axle. Well see , might have to go to grabd tapids after work.
them bitches are heavy. one tire took literaly 8 oz to balnce and another took 0.5 oz..well see how it rides in a couple months. That turbo eill definitly be necessary to turn these things.
  #44
Old 08-10-2014, 10:28 PM
Greg5OH's Avatar
Greg5OH
Greg5OH is offline
  #45
Old 08-11-2014, 04:56 PM
eakermeld's Avatar
eakermeld
eakermeld is offline
I don't know much about resto-mods, but doesn't the cab go on and then the seat goes IN the cab?
Quick Reply: 91 crewcab with SD running gear. Frame off resto build.
