91 crewcab with SD running gear. Frame off resto build. - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-23-2014, 11:58 AM
damarble damarble is offline
damarble is gaining momentum as a positive member of FTE.damarble is gaining momentum as a positive member of FTE.
Dang it I was really hoping you'd follow through with the Hummer wheels. I want to run 05+ axles but also MTRs and I still don't know if it can be done for sure.
  #32
Old 07-23-2014, 12:03 PM
Greg5OH Greg5OH is offline
Greg5OH is starting off with a positive reputation.
i can tell you for sure from a bunch of threads I have seen, 16.5" wheels will only clear if you run a minimum of 3.5" back spacing.
the 17s I got are tight around the front calipers, cant fit a finger in there.
9" wide 0 offset.
and recentered to an 8x170 of course.
No real way around this unless oyu get custom spacers from arrowcraft and thats 720 for 4 of em. The 8x170 really screws it up for running military wheels on the cheap.
with new wheels and tires, black rock 997s, cooper s/t maxx 37s, taxes mounted installed etc total package im at 1700. Its alot but 17s are more common and can run any tire I wish pretty much. The wheels are i think 16-17 pounds lighter a piece than the 24 bolt h1 wheels too. the h1s do look bad *** though.
  #33
Old 07-23-2014, 12:42 PM
I've heard about the 3.5" rule but nothing concrete. I don't even care about the Hummer wheels, it's the tires I want. Plain steelies work for me since I won't be airing down. If I can get some aftermarket steelies in 8x170 with enough backspacing and a high load rating I'll be set.
  #34
Old 07-23-2014, 10:50 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
You know about the Rockstars cracking, right?
  #35
Old 07-23-2014, 10:55 PM
no one is running rock star wheels?
  #36
Old 07-24-2014, 05:47 AM
Quote:
On an OBS? I hope not, they are Ugly as FAUK
  #37
Old 07-24-2014, 07:32 AM
i meant, i dunno where you got the comment of Rockstar wheels from. the wheels I got are made by black rock/cragar. -dunno
  #38
Old 07-24-2014, 08:36 PM
I must have mis read
  #39
Old 08-04-2014, 04:33 PM
dont update much ver here, my main thread is ove ron oil burners.
heres some pics that came in or are coming in.
$30 bucks for htis, picked up a 2500# wireless remote winch to replace the hand crank.
painted. buiulding the rear parking brakes up tonight
should be in next week.
C code springs
06 172" WB frame from texas, got my first coat of paint on it. Came with a class 5 hitch on it already. No fuel tank as of yet, want to get a roller on tires first to see what im dealing with. these new frames have a big cross memebr on the rear.
tires should be here in a couple days. Got some 2" long spline drive lug nuts so people dont punk my wheels.
ordered a set of header flanges from justin at R&D to start mocking up my customheaders and uppipes for the turbo, and a bunch of V band clamps.
going to grab a 6.0 intercooler soon, waiting on a set of factory 4" lift blocks for the rear, Should be a full roller by end of next week.
  #40
Old 08-04-2014, 05:11 PM
emspjay's Avatar
emspjay emspjay is offline
emspjay is gaining momentum as a positive member of FTE.emspjay is gaining momentum as a positive member of FTE.
Looking good!! Great thread!!
  #41
Old 08-04-2014, 05:16 PM
GuitarJesus's Avatar
GuitarJesus GuitarJesus is offline
GuitarJesus is gaining momentum as a positive member of FTE.
C code springs
Dude this is killer. How much fab work are you going to have to do to get the cab to bolt up and sit right? Is the frame the same width? I thought SD frames were wider.
  #42
Old 08-04-2014, 10:22 PM
frame is 37" wide. pretty sure obs frames are the same.
I dunno i figured moving or making a couple cab mounts is the easy part vs fabbing trac bar mounts, sway bar mounts, drilling liek 50 new holes, lining up the radius arms etc.
one thing i dont know how to do yet is adapting my steering column to the new 05 steering shaft, and how to use the SD PS pump for the hydroboost. OR get an old F-superduty PS pump but then i need metric to std fittings. everything else should just drop right on. Im making my own front end and rad support so im not worried about things lining up. Im not going for a factory look
  #43
Old 08-07-2014, 12:38 AM
Tomorrow paintning underside of front axle. Well see , might have to go to grabd tapids after work.
them bitches are heavy. one tire took literaly 8 oz to balnce and another took 0.5 oz..well see how it rides in a couple months. That turbo eill definitly be necessary to turn these things.
  #44
Old 08-10-2014, 11:28 PM
  #45
Old 08-11-2014, 05:56 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
I don't know much about resto-mods, but doesn't the cab go on and then the seat goes IN the cab?
Highboy Information Compilation zerfetzen 1973 - 1979 F-100 & Larger F-Series Trucks 107 02-07-2017 06:23 PM
Stoooopid Dually Questions BruteFord 1987 - 1996 F150 & Larger F-Series Trucks 74 08-21-2016 10:55 PM
88' F350 CC DRW frame question abosely 1987 - 1996 F150 & Larger F-Series Trucks 3 12-03-2015 07:56 AM
Rim offset help for dually converted to single wheel nuljas23 1999 to 2016 Super Duty 7 09-18-2015 10:54 PM
f-350 single rear wheel to a dually? 1978fordf250 1987 - 1996 F150 & Larger F-Series Trucks 1 09-21-2010 07:36 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
