Adding hydraulic fluid to dump cylinder - Ford Truck Enthusiasts Forums
Old 07-07-2014, 12:10 AM
Scoop65 Scoop65 is offline
Scoop65 is starting off with a positive reputation.
My 51 F8 dump box is moving slowly. I suspect it needs so fluid, but I am quite unsure where to fill since it seems to have no reservoir. The only visible opening seems to be on the cylinder itself and that would require the box to be raised to access. That seems like a not very good idea, so perhaps there is some other answer. Can anyone give me advice.
Old 07-07-2014, 05:01 AM
big job's Avatar
big job big job is offline
big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.big job has a very good reputation on FTE.
I'm afraid you answered your own question. There is no other way other
than to lift the body high enough to get oil in there on the "top" filler
plug. Either by using jacks, or a loader or a chain fall. Make sure its
prop'ed good. Keep adding fluid until the piston fully extends and working
it up and down until the system stabilizes. And also you may get soaked.
Most plugs have a pin hole to vent the air. The best solution is- to add
hydraulic oil when you first notice the body not going all the way up.
The CAUTION: many have been killed not propping bodys.!!!
Real life example; couple yrs ago I have 17 ton of asphalt (with a L9000)
I back up to the paver, just about 3/4 the way up the high pressure line
(hose) exploded ! The body still with most of 17 ton came down in a split
sec. bent the chassis the cab shield flatted the roof blew out all the glass
and door frames and I cant get out-I crawled out thru the windshield.
The crew said the front end came up about 4 feet in the air sounded like
a bomb. And being a L9000 with a 3306 Cat -thats a heavy front end, but
still no match for a 17 ton slam...
So be careful my friend.......
sam
edit the truck was totalled and towed away still with about $2000 asphalt in it.
Old 07-07-2014, 09:25 AM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Yes, as said above, the reservoir is part of the cylinder. If you don't see any major leaks any where, it may be a problem with the pump or valving. Usually, if low on oil they will raise normal speed, but only part way.
And again.....please be careful under there!
Brakes go to the floor Fastback460 1987 - 1996 F150 & Larger F-Series Trucks 26 06-18-2015 09:29 PM
1973 F600 DUMP HYDRAULIC PTO PUMP BERTRAM42 Large Truck 11 09-18-2014 09:30 PM
F600 HYDRAULIC DUMP TRUCK PUMP BERTRAM42 Large Truck 3 09-16-2014 09:32 AM
Reccomended Fluid for F600 dump hydraulic cylinder? 1975-F6004x4Dump Large Truck 5 02-07-2014 10:41 PM
1967 F350 Dump bed piney1 1967 - 1972 F-100 & Larger F-Series Trucks 5 10-07-2010 05:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
