A spark plug just came out by itself... - Page 2 - Ford Truck Enthusiasts Forums
Old 07-09-2014, 03:22 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Most likely the plug was stripped before you got it. They don't just fall out. When I said they sometimes do, I meant as the result of improper installation; too much torque, too little torque, wrong plug, etc.
Old 07-09-2014, 03:31 PM
Creach Creach is offline
Creach is starting off with a positive reputation.
I hear ya. I bought this truck used in 09 and haven't needed to do anything to it, so whatever has happened was begun long ago. I've put 30k miles on it.
And an update is in order: The dealer says: yup, it's stripped. The force of the plug expulsion not only shredded the COP boot, but also cracked the coil housing, too. So far, the estimated cost is roughly $185 and an overnight stay.
Old 07-09-2014, 04:22 PM
Final update: All done. Pickup tomorrow morning.
Service writer originally told me $100 to fix, mech had $200 on the clock - writer bumped that back to the original $100. Insert kit (he forgot to mention) $45, COP $85.
Thank you all for your helpful comments. I surely hope that the old owner or *their mech* didn't cross-thread any more sparkplugs.
Creach
Edit: I forgot to mention that when this all occurred, to me (in the driver's seat) it sounded much like a tire blowout, and then an open exhaust header. And in addition I discovered that my air conditioning quit at the same time. The service writer would tell me that this had more to do with an engine misfire fault than with an air conditioning issue. I later discovered he was correct.
Old 07-10-2014, 10:29 AM
1saxman's Avatar
Yeah, they put a HeliCoil in it. I think you did okay - they could have really ripped you a new one; like, a new cylinder head, for example.
Old 07-10-2014, 10:59 AM
1saxman, I was *very* concerned that the dealer wasn't going to be able to do it without pulling the head to re-thread it.
Creach
Old 07-10-2014, 11:32 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The dealer should have installed a Lock 'n Stitch insert, not a helicoil. Don't confuse the two. It's not necessary to remove heads to install inserts on the Ford modular engines, the service can be performed in-vehicle. Several cylinders are easy, several are tough but doable.
At a dealer, $230 is a good deal for this repair.
Lifters. Suggestions anyone? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 02-17-2016 11:04 PM
chuffing noise? Macrobb Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 09-29-2015 10:13 PM
Intermittent thud upon cold start? dropitlow88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 2 04-23-2015 01:38 PM
93 IDI Problems Please Help Countrybob Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-06-2015 09:53 PM
engine swap pro's and con's Old Brown Truck FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 12-02-2014 06:23 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
