Joined this side of the forum also and have a few questions?
Old 07-15-2014, 12:53 PM
Gettysburg150's Avatar
Gettysburg150
Gettysburg150 is offline
I'd be patient on the genny start up, if its been sitting for a while you might want to do a couple simple checks before operating her, plus you'd want to do a good run cycle to get it working good again, they like to be under load, but enough about that for now.
I'd suspect wiring, probably a bad ground that they all tie into or something
Old 07-15-2014, 01:02 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Redneckfordf2502002 is offline
Oh trust me once it starts up and I run it a few seconds I will hook the power off our solar system to it so we can charge our batteries just to make sure it all works I won't let it run without a load. LOL That's just how it is when you live out in the backwoods.
That's what I am thinking but I am also wondering about bulbs. I know sometimes they set them up all on one circuit and if one goes out they all go out. I know that somebody put 1157 bulbs in the reverse which doesn't work you have to run 1156 (ask me how I know my 88 F150 had one 1157 for the reverse and that one didn't work put an 1156 in and it worked great.) Not sure yet I haven't had a chance to get to it being I got a flat on my dad's 89 F250, our trail truck is giving us problems, and working on the house.
Trav
Old 07-15-2014, 01:28 PM
Gettysburg150
Well before you run it good I'd def put new oil and throw a filter on (if that model has a serviceable fitler), then probably run it for a half hour before throwing a gradually increasing load, but make sure you remove the load before shut down! You'll make a paperweight real quick.
Bulbs are easy to check, ohm em out. If they're open, no beuno, some resistance, still good
Old 07-15-2014, 01:32 PM
Redneckfordf2502002
thanks definatly will do all that. Might change the oil when I change the oil on the motorhome since it needs one.
Trav
JimiLL
03-23-2012 10:36 PM
RojoStar
Aerostar
01-18-2012 11:27 AM
rwdfan
07-04-2011 04:29 AM
Jfrei
11-05-2009 06:21 PM
Bignorse
1978 - 1996 Big Bronco
08-21-2003 10:17 AM
Quick Reply: Joined this side of the forum also and have a few questions?
