What's up with this front end? - Ford Truck Enthusiasts Forums
Old 07-06-2014, 07:31 PM
Doc's Avatar
Doc Doc is online now
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
At first, this truck really intrigued me because it's described as still having a flathead six with modern look with the newer wheels and seat. But then I noticed the front end. What is going on with the lower part of that grill and those two lower fenders? Fiberglass with a VERY bad fit? I can't figure it out. Nevertheless, it's a pretty solid looking truck.
1950 Ford truck
Old 07-06-2014, 08:46 PM
FortyNiner's Avatar
FortyNiner FortyNiner is offline
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Might be larger truck upper fenders with F1 lowers. Definitely not a stock look.
Old 07-06-2014, 09:12 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Looks like the lower fenders are pushed or bent way back near the frame.
Old 07-06-2014, 11:06 PM
bobbytnm's Avatar
bobbytnm bobbytnm is offline
Roast em' if you got 'em
bobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud ofbobbytnm has much to be proud of
Hmmmm, that is odd
My guess is a mismatch between F1 parts and larger truck parts like FortyNiner suggested.
Bobby
Old 07-07-2014, 12:39 PM
bobj49f2's Avatar
bobj49f2 bobj49f2 is offline
bobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud ofbobj49f2 has much to be proud of
Even it the fender bottoms were from a F-2 to F-6 they would still fit better around the grill, the trucks up to F-6 all share the same grills. The side view of the truck seem to show the longer F-1 angled seem but I couldn't blow them up enough to see that are real good.
If they were from a F-7 or 8 they wouldn't fit at all because the grills on the larger truck are a lot wider than the smaller truck.
I have a feeling there are two things going on here to make it look odd. First, the center part is a fiberglass piece that doesn't exactly match the fenders. Second, I think there's a darker colored paint or primer on the fender under the head lights so it makes it look like there's a gap or shadow when there isn't one. Same with the area around the frame notch on the fenders, it makes it look like their setting further back than the center panel. This truck looks like it could have had some quickie body work done to it and then had a quick coat of beige epoxy primer hosed onto it.
Also, maybe the person who installed the fender made the common mistake of thinking the top edge of the fender bottom should match up with the lip of the upper fender when there should be a difference to mimic the body line on the back of the fender. In trying to line up the two lips he might have pushed the fender bottom back some.
Those are my guesses.
Old 07-07-2014, 01:02 PM
dmack91's Avatar
dmack91 dmack91 is offline
dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.dmack91 has a great reputation on FTE.
The lower fenders look like they hit the frame where they should. Almost looks like the grill is possibly put in at an angle, with the bottom sticking out further than the top, then bolted the gravel pan to the bottom grill support.
I have a hard time believing that both lower fenders could be pushed back that far without some significant damage being evident.
Old 07-07-2014, 01:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
My guess is that the lower valance is home made. What is the black around the grille, looks like rubber? Someone should call...
Old 07-07-2014, 04:31 PM
bobj49f2's Avatar
Doc, who is the member who lives in Lexington? He was at TS '13. He used to live in the Chicago area. I think it's Dave, 49f3dls, but his location says "Central KY", the person I am thinking, I think, list their location as "Lexington". Maybe he could check out the truck and report back.
To that member, I am sorry I don't remember who you are. I get lost with all these board names. I know who I'm talking about, I just don't remember your name.
bobj49f2's Avatar
95 f250 ground strap question cranegrad 1987 - 1996 F150 & Larger F-Series Trucks 7 09-23-2016 09:19 AM
2004 F250 Lariat V10 chefcollins1 Vehicles for Sale 0 05-03-2016 10:16 PM
Project "pass it on" build thread Ron94150 1987 - 1996 F150 & Larger F-Series Trucks 45 03-01-2016 09:52 AM
Excursion What If's BassFantasizer Excursion - King of SUVs 11 09-18-2015 09:29 PM
F350 Dually- raising the front end canuckelhead 1999 - 2003 7.3L Power Stroke Diesel 1 01-24-2009 04:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
