Carburetor Identification - Ford Truck Enthusiasts Forums
Old 07-06-2014, 07:26 PM
AberrantGenus AberrantGenus is offline
AberrantGenus is starting off with a positive reputation.
Hi, I just bought a 67 f100. It has a 460 out of a 71 crown vic or grand marques. Can anyone tell me what kind of Holly this is so I can get a rebuild kit? It is stamped with List-3310-2 2D45. Not sure if that is a "D" or a "0". Also in the second picture you can see an aluminum tubed wrapped in a braded cotton of some sort. It comes out of the carb and loops around the exhaust manifold and doesnt go anywhere. What is the purpose of it?
Old 07-06-2014, 07:31 PM
oh sorry. it is a Holly
Old 07-06-2014, 10:17 PM
redroad's Avatar
redroad redroad is offline
redroad has a good reputation on FTE.redroad has a good reputation on FTE.
The heat tube supplies hot air to the choke .. Some electric chokes although electric still require a hot air source .. Your carb's model number is a 4160 .. Get a Holley brand kit for a 4160 don't use any other substitute .. It does matter
The 3310-1 is actually a 4150 carb, because its got a metering block (removeable jets) on the secondaries. The 3310-2 through 6 are 4160 style, because they use a metering plate for the secondaries (non-removeable jets).
http://www.holley.com/data/Ads/3310page.pdf
Old 07-06-2014, 11:01 PM
Thanks for the info redroad. So, for not other reason than it is ugly, is there something else I can do with the heat tube? the outside and interior of the truck are almost perfect. I would like to get the engine compartment to match.
Old 07-06-2014, 11:33 PM
redroad's Avatar
Quote:
You can get Choke Conversion Kit PART #: 45-223
Holley Performance Products Choke Conversion Kit 45-223
http://www.holley.com/data/Products/...R7972-4rev.pdf
Old 07-09-2014, 10:55 PM
Got it all done. Thanks for the help. I cant believe what a difference a carb kit makes.. 100% improvement.
Old 07-10-2014, 08:26 AM
redroad's Avatar
excellent !
1982 150 XLT Lariat 4X4 Value Youthdude 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 12-23-2016 09:10 PM
Caution Ford GT Porn chruby99 General Automotive Discussion 8 12-20-2016 09:27 PM
Carburetor help Jsek 1957 - 1960 F100 & Larger F-Series Trucks 5 12-07-2016 09:42 PM
Finally! drivesprocket 2017 Super Duty 17 09-09-2016 10:15 AM
TRAIN WRECK engine bay, HELP. Warning Pic Heavy! wintertruck87 1987 - 1996 F150 & Larger F-Series Trucks 28 11-21-2014 11:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
